  • 2
  • 4(current)
  • 6
  • 8
Release IGN.com - Game and movie news
#46
Who can fix this?
#47
The Plex channel is doing the same thing. I think ign screws up the way they categorize videos or something.
#48
I guess this add on is done Sad
#49
Sorry for the delay. I have been realy busy during the last couple of weeks and only noticed the problem yesterday.
IGN sure likes to keep changing their page layout a lot. The fix should show up in the official repository soon.
For the impatient: you can also download the fix here: https://github.com/twister-kodi/plugin.video.ign_com
2.1.4
- Adjusted file paths for video reviews and IGN-Daily-Fix to match new layout of web page
#50
Thanks for fixing IGN Daily Fix Twister Smile
#51
Great work Twister. Thanks!
I noticed something odd though. When watching this video (http://www.ign.com/articles/2015/11/10/s...view?watch) in kodi with the setting on 360p, it didn't play. It seems that the bitrate isn't always 1000000. In this case it was 500000. Some other videos in the reviews worked fine on 360p, some didn't.
All seems ok for the the higher resolutions.
#52
(2015-11-13, 19:34)Skipmode A1 Wrote: Great work Twister. Thanks!
I'll look into it.
Edit: I think I found the problem. Please check out the new version in above repo and let me know if you still have problems.
#53
That seems to have fixed the problem, thanks Smile.
#54
+1 great job
#55
(2014-05-27, 23:35)sarlan19 Wrote: Sorry to wake an sleeping thread :-)
Is there a way to get 1080p video in the addon as they are available on site.
tnx
+1 for 1080P Smile
#56
tnx
+1 for 1080P Smile
Was this a request or a thank you? Because in any case AddonScriptorDE had already implemented it before I took over Wink
#57
tnx
+1 for 1080P Smile
It was a Request
1080P does not seem to work for me.
#58
Works fine for me. I couldn't find any post of you about your problem. Could you please specify it? Did you change max resolution in addon settings to 1080p? What Kodi Version are you using?
#59
That's strange I just checked and it was only set to 720P.
I thought for sure I had set it to 1080P anyway glad it's working Smile
Thanks Twister for updating IGN Smile
#60
Hello,
Sorry to report but something must have changed again over at IGN because the IGN add on is not working correctly again,
IGN Daily Fix, IGN Live and IGN First, are not working at all.
Twister any chance of getting this fixed again? Smile
  • 2
  • 4(current)
  • 6
  • 8
IGN.com - Game and movie news0
