hello Curti
I am not a well versed kodi modifier could you please guide me on how to install this add-on. I will try it thank you
Best regards to all
BikerDude
HTPC with 16gb ram M-Audio LT1010 sound card feeding McIntosh 7205 power amp Magneplanar 2.7r and Velodyne dd12. All connected to Sony smart tv.
All media on 2 fully redundant TrueNas VMs installed on Proxmox servers. Running Kodi. Everything works brilliantly until i screw it up
Hello Curti
Many thanks for this add on and your assistance. This is on of the features I was looking for in Kodi. May I suggest to add an option to create a new play list from this context menu to this add on and then add the songs to this new playlist.
Kodi should also add the option to remove duplicates songs in the edit playlist environment
as I suggested in an other thread, I would like Kodi to add a specific section ( threads) to their forums specifically focus on music.
This would allow Kodi to prioritise new development relating to adding, managing, and playing ones music library. There is much work to be done to the Kodi music environment for it to be world class.
Best regards to all
BikerDude
zag
Team-Kodi Member
I've now marked this thread as solved, as an Add-on has been created.
Thanks Curti!
2016-03-13, 00:47
(This post was last modified: 2016-03-13, 00:48 by Hollako.)
Hello,
The add-on works great !!
A small new feature should be added as well in the Kodi mobile application so we can add music to library when we surf in music library through the mobile application. is it possible?
Thank you.
Hello,
Is this addon still available? The links above point to a Dropbox location that is no longer available. Reading this thread, this feature seems like what I am looking for so I would like to try it.
You are right. The download link is down and it was not uploaded to a repo i think. I'd ask in the development thread for a reupload and submission to kodi repo. I might have a copy that i could upload but on the long run the best thing would be if the addon becomes widely available in kodi's repo.
