[ 1597.768347] smsc95xx 1-1.1:1.0: eth0: kevent 2 may have been dropped (times 50) Video stops playing and returns to home screen.
when playing HD movies via the youtube plugin version 12350 version 12026 is working ok (except for aspect ratio of pictures)
Hi everyone, I'm new on this OpenELEC for Raspberry and I'd like to know, is it possible to set output resolution to 1024x768 ? I'd like to use this baby with a led projector and native resolution is that one, so, is it possible ?
R12349 and some keyboard shortcuts seem to have gone missing. "M" no longer brings up the playback controls and "I" doesn't bring up the info on selected item. May well be others that I don't know about.
2012-11-03, 18:45
(This post was last modified: 2012-11-03, 18:56 by Wanderlei.)
169.254.92.194 I think loop back address, it is not getting IP properly from DHCP. Check that or try static IP.
I use SMB to get shares from a windows 7 machine, maybe try that way.
I was wondering which of my R-Pi's would be the superior OpenELEC XBMC machine.
R-Pi A - 256mb
arm_freq=900
sdram_freq=450
core_freq=350
R-Pi B - 512mb
gpu_mem=256
arm_freq=900
sdram_freq=450
Basically one is a 512MB board but core_freq must run at stock AND the 256MB can overclock core_freq to 350. (but obviously less memory)
I am leaning towards the one with the faster gpu core speed, I would imagine this to be an advantage for video playback and such. The 512MB board, it just seems to have more memory free.
2012-11-03, 19:42
(This post was last modified: 2012-11-03, 19:43 by caravela.)
when overclocking the arm_freq is the most important thing, the other options don't have a high impact in performance. the GPU seems to handle everything fine (as long it has enough ram available for it...) . on the other hand you will notice that setting a higher CPU, will yield a better response feedback from the system due to the cpu being faster processing data when entering libraries menus, on online addons fetching and parsing data is way quicker as well.
for the 512 MB having some extra ram for caching also helps improving networking performance and allowing more background services
