here is my file
i'm inclined to say the thing making the difference is LCD_DRIVER="none" , this was one of the things changed in the latest commits
# Name of the Distro to build (full name, without special charcters)
DISTRONAME="OpenELEC"
# Welcome Message for e.g. SSH Server (up to 5 Lines)
GREETING0="##############################################"
GREETING1="# OpenELEC - The living room PC for everyone #"
GREETING2="# ...... visit http://www.openelec.tv ...... #"
GREETING3="##############################################"
GREETING4=""
# Hostname for target system (openelec)
HOSTNAME="openelec"
# Root password to integrate in the target system
ROOT_PASSWORD="openelec"
# User to integrate in the target system
USER_NAME="openelec"
# User group to integrate in the target system
USER_GROUP="openelec"
# User password to integrate in the target system
USER_PASSWORD="openelec"
# The TARGET_CPU variable controls which processor should be targeted for
# generated code.
case $TARGET_ARCH in
i386)
# (AMD CPUs) k8 k8-sse3 opteron opteron-sse3 athlon64 athlon64-sse3
# athlon-fx athlon-mp athlon-xp athlon-4
# athlon-tbird athlon k6-3 k6-2 k6 geode
# (Intel CPUs) atom core2 nocona prescott pentium4[m] pentium3[m]
# pentium-m pentium2 pentiumpro pentium-mmx pentium
# i686 i586 i486 i386
# (VIA CPUs) c3 c3-2
TARGET_CPU="atom"
x86_64)
# athlon-fx amdfam10 barcelona
TARGET_CPU="atom"
arm)
# TARGET_CPU:
# arm2 arm250 arm3 arm6 arm60 arm600 arm610 arm620 arm7 arm7m arm7d
# arm7dm arm7di arm7dmi arm70 arm700 arm700i arm710 arm710c
# arm7100 arm720 arm7500 arm7500fe arm7tdmi arm7tdmi-s arm710t
# arm720t arm740t strongarm strongarm110 strongarm1100
# strongarm1110 arm8 arm810 arm9 arm9e arm920 arm920t arm922t
# arm946e-s arm966e-s arm968e-s arm926ej-s arm940t arm9tdmi
# arm10tdmi arm1020t arm1026ej-s arm10e arm1020e arm1022e
# arm1136j-s arm1136jf-s mpcore mpcorenovfp arm1156t2-s
# arm1176jz-s arm1176jzf-s cortex-a8 cortex-a9 cortex-r4
# cortex-r4f cortex-m3 cortex-m1 xscale iwmmxt iwmmxt2 ep9312.
TARGET_CPU="arm1176jzf-s"
# TARGET_FLOAT:
# Specifies which floating-point ABI to use. Permissible values are:
# soft softfp hard
TARGET_FLOAT="hard"
# TARGET_FPU:
# This specifies what floating point hardware (or hardware emulation) is
# available on the target. Permissible names are:
# fpa fpe2 fpe3 maverick vfp vfpv3 vfpv3-fp16 vfpv3-d16 vfpv3-d16-fp16
# vfpv3xd vfpv3xd-fp16 neon neon-fp16 vfpv4 vfpv4-d16 fpv4-sp-d16
# neon-vfpv4.
TARGET_FPU="vfp"
esac
# Build optimizations (size/normal/speed)
OPTIMIZATIONS="speed"
# Project CFLAGS
PROJECT_CFLAGS=""
# LTO (Link Time Optimization) support
LTO_SUPPORT="yes"
# Bootloader to use (syslinux / u-boot / atv-bootloader / bcm2835-bootloader)
BOOTLOADER="bcm2835-bootloader"
# Configuration for u-boot
UBOOT_CONFIG=""
# Kernel to use. values can be:
# default: default mainline kernel
# ti-omap4: Ti's OMAP4 kernel
LINUX="default"
# use linux-next (latest rc) instead latest released version
LINUX_NEXT="no"
# SquashFS compression method (gzip / lzo / xz)
SQUASHFS_COMPRESSION="lzo"
# Mediacenter to use (xbmc / no)
MEDIACENTER="xbmc"
# Skins to install (Confluence)
# Space separated list is supported,
# e.g. SKINS="Confluence"
SKINS="Confluence"
# Default Skin (Confluence)
SKIN_DEFAULT="Confluence"
# install extra subtitle Fonts for XBMC (yes / no)
XBMC_EXTRA_FONTS="yes"
# Plugins for XBMC to install (SABnzbd)
# e.g. XBMC_PLUGINS="SABnzbd"
XBMC_PLUGINS=""
# build and install 'RSXS' Screensaver (yes / no)
XBMC_SCR_RSXS="no"
# build and install 'ProjectM' Visualization (yes / no)
XBMC_VIS_PROJECTM="no"
# build and install 'GOOM' Visualization (yes / no)
XBMC_VIS_GOOM="no"
# build and install ALSA Audio support (yes / no)
ALSA_SUPPORT="no"
# build and install PulseAudio support (yes / no)
PULSEAUDIO_SUPPORT="no"
# build and install with non-free support
# (RAR compression support in XBMC) (yes / no)
NONFREE_SUPPORT="yes"
# build and install with DVDCSS support
# (DVD decryption support in XBMC) (yes / no)
DVDCSS_SUPPORT="no"
# build and install with LAME cdrip encoder support
ENCODER_LAME="no"
# build and install with VORBIS cdrip encoder support
ENCODER_VORBIS="no"
# build and install with BluRay support (yes / no)
BLURAY_SUPPORT="no"
# additional drivers to install:
# for a list of additinoal drivers see packages/linux-drivers
# e.g. ADDITIONAL_DRIVERS="DRIVER1 DRIVER2"
ADDITIONAL_DRIVERS="RTL8192CU"
# build with network support (yes / no)
NETWORK="yes"
# build and install bluetooth support (yes / no)
BLUETOOTH_SUPPORT="no"
# build and install with XBMC webfrontend (yes / no)
WEBSERVER="yes"
# build and install Avahi (Zeroconf) daemon (yes / no)
AVAHI_DAEMON="yes"
# build with AirPlay support (stream videos from iDevices to XBMC) (yes / no)
AIRPLAY_SUPPORT="no"
# build with AirTunes support (stream music from iDevices to XBMC) (yes / no)
AIRTUNES_SUPPORT="no"
# build with libnfs support (mounting nfs shares with XBMC) (yes / no)
NFS_SUPPORT="yes"
# build with afpfs-ng support (mounting AFP shares with XBMC) (yes / no)
AFP_SUPPORT="no"
# build and install Samba Client support (yes / no)
SAMBA_CLIENT="yes"
# build and install Samba Server (yes / no)
SAMBA_SERVER="yes"
# build and install SFTP Server (yes / no)
SFTP_SERVER="no"
# build and install SSH Guard (yes / no)
SSHGUARD_SUPPORT="no"
# build and install PPP support (yes / no)
PPTP_SUPPORT="no"
# build and install OpenVPN support (yes / no)
OPENVPN_SUPPORT="no"
# build and install diskmounter service (udisks)
# this service provide auto mounting support for external drives
# in the mediacenter also automount internally drives at boottime (yes / no)
UDISKS="yes"
# build and install powermanagement support (upower) (yes / no)
UPOWER="no"
# build and install exFAT fuse support (yes / no)
EXFAT="no"
# build and install NTFS-3G fuse support (yes / no)
NTFS3G="no"
# build and install hfs filesystem utilities (yes / no)
HFSTOOLS="no"
# OpenGL(X) implementation to use (no / Mesa)
OPENGL="no"
# OpenGL-ES implementation to use (no / bcm2835-driver)
OPENGLES="bcm2835-driver"
# Windowmanager to use (ratpoison / none)
WINDOWMANAGER="none"
# Displayserver to use (xorg-server / no)
DISPLAYSERVER="no"
# Xorg Graphic drivers to use (all / i915,i965,r200,r300,r600,fglrx,nvidia,nouveau,vmware)
# e.g. GRAPHIC_DRIVERS="i915 i965 r300 r600 radeon nvidia nouveau"
GRAPHIC_DRIVERS=""
# OpenMAX implementation to use (no / bcm2835-driver)
OPENMAX="bcm2835-driver"
# Use VDPAU video acceleration (needs nVidia driver and a supported card)
VDPAU="no"
# Use VAAPI video acceleration (needs intel i965 driver and a supported card)
VAAPI="no"
# Use XVBA video acceleration (needs AMD fglrx driver and a supported card)
XVBA="no"
# Use Broadcom CrystalHD Decoder Card for video acceleration
# (needs Kernelsupport for Broadcom Decoder Card and a supported card)
CRYSTALHD="no"
# build and install remote support (yes / no)
REMOTE_SUPPORT="no"
# build and install ATV IR remote support (yes / no)
ATVCLIENT_SUPPORT="no"
# build and install IRServer IR/LCD support (yes / no)
IRSERVER_SUPPORT="no"
# build and install Joystick support (yes / no)
JOYSTICK_SUPPORT="no"
# build and install CEC adapter support (yes / no)
CEC_SUPPORT="yes"
# build and install iSCSI support - iscsistart (yes / no)
ISCSI_SUPPORT="no"
# LCD driver to Use - Possible drivers are ( Comma seperated:
# bayrad,CFontz,CFontz633,CFontzPacket,curses,CwLnx,dm140,
# ea65,EyeboxOne,g15,glcdlib,glk,hd44780,i2500vfd,
# icp_a106,imon,imonlcd,IOWarrior,irman,irtrans,
# joy,lb216,lcdm001,lcterm,lirc,lis,MD8800,mdm166a,
# ms6931,mtc_s16209x,MtxOrb,mx5000,NoritakeVFD,
# picolcd,pyramid,sed1330,sed1520,serialPOS,
# serialVFD,shuttleVFD,sli,stv5730,SureElec,svga,
# 'all' compiles all drivers;
# 'all,!xxx,!yyy' de-selects previously selected drivers
# "none" for disable LCD support
LCD_DRIVER="none"
# Modules to install in initramfs for early boot
INITRAMFS_MODULES=""
# additional Firmware to use (dvb-firmware, misc-firmware, wlan-firmware)
# e.g. FIRMWARE="dvb-firmware misc-firmware wlan-firmware"
FIRMWARE="misc-firmware wlan-firmware"
# build with lm_sensors hardware monitoring support (yes / no)
SENSOR_SUPPORT="no"
# build with swap support (yes / no)
SWAP_SUPPORT="no"
# swapfile size if SWAP_SUPPORT=yes in kB (example: 262144 = 256MB )
SWAPFILESIZE="262144"
# build with automatic update support (yes / no)
UPDATE_SUPPORT="yes"
# build with installer (yes / no)
INSTALLER_SUPPORT="no"
# Testpackages for development (yes / no)
TESTING="no"
# OEM packages for OEM's (yes / no)
OEM_SUPPORT="no"
# Coreboot support (yes / no)
COREBOOT="no"
# Distribution Specific source location
DISTRO_MIRROR="http://sources.openelec.tv/mirror"
DISTRO_SRC="http://sources.openelec.tv/$OPENELEC_VERSION"
# Addon Server Url
ADDON_SERVER_URL="http://addons.openelec.tv"
# set the addon dirs
ADDON_PATH="$ADDON_VERSION/$PROJECT/$TARGET_ARCH"
ADDON_URL="$ADDON_SERVER_URL/$ADDON_PATH"
On top of that i have this patch for having a 1080p gui, xbmc-25bb46a-999-1080p.patch in folder packages/mediacenter/xbmx/patches
diff --git a/xbmc/windowing/egl/EGLNativeTypeRaspberryPI.cpp b/xbmc/windowing/egl/EGLNativeTypeRaspberryPI.cpp
--- a/xbmc/windowing/egl/EGLNativeTypeRaspberryPI.cpp 2012-11-16 09:57:46.234206933 +0000
+++ b/xbmc/windowing/egl/EGLNativeTypeRaspberryPI.cpp 2012-11-16 09:58:25.102205296 +0000
@@ -554,7 +554,7 @@
bool CEGLNativeTypeRaspberryPI::ClampToGUIDisplayLimits(int &width, int &height)
- const int max_width = 1280, max_height = 720;
+ const int max_width = 1920, max_height = 1080;
float ar = (float)width/(float)height;
// bigger than maximum, so need to clamp
if (width > max_width || height > max_height) {
