2012-09-23, 10:47
I think the Raspbmc XBMc version is probably too old. RC5 should be out next week, then we'll get newer nightlies and it <should> work.
(2012-09-22, 17:04)A600 Wrote:(2012-09-21, 16:33)Mrbob2 Wrote: Would it help if we raised a ticket/bug tracker in XBMC (if I can) to have that bug patched?
Group management is a strong part of the PVR function, works with Mediaportal TV server.
There is one and a PR with a fix
(2012-09-25, 10:03)Steini1971 Wrote: Hi,
yes, it works very good with windows 7, but not the recordings.
First it needs a loong time to see the recordings, maybe 20 seconds, every time I go to recordings.
If I want to play a recording, I got a message. To play this file is not possible, for details go to.... And this is the End of msgbox.
But in the End I play the recording. But I connot navigate the recording. Any idea?
(2012-09-26, 12:35)boborg Wrote: Is there any trick to installing this (xbmc windows version)? I have tried the install from zip but i responds that it addon does not have the correct structure.
Never mind did not seem the nightly build requirement.
