2012-10-10, 12:41
(2012-10-10, 12:39)`Black Wrote: I want a setting where I can disable randomize time... updating on database update etc. is fine.
will do
(2012-10-10, 11:57)phil65 Wrote: will it be possible to manually trigger randomizing of items? thx.
<onclick>PlayMedia($ESCINFO[Window.Property(RandomMovie.1.File)])</onclick>
<onclick>RunScript(service.skin.widgets)</onclick>
RunScript(service.skin.widgets,random=true&recommended=false)
(2012-10-10, 12:46)`Black Wrote: Thanks. The default slider value for randomize time needs to be fixed, too... it's 1 by default and if you change it, you can only set to 10 or more minutes. I guess it should be 10 by default?
<thumb>$INFO[Window(home).Property(RecommendedMovie.1.Thumb)]</thumb>
<icon>$INFO[Window(home).Property(RecommendedEpisode.1.TvshowThumb)]</icon>
(2012-10-10, 20:28)butchabay Wrote: Thanx,
I think see the bug.
there must be window(home).property
Will try and report.
Ha, thanx hitcher
(2012-10-10, 20:31)Martijn Wrote:(2012-10-10, 20:28)butchabay Wrote: Thanx,
Ha, thanx hitcher
k that seems to have vanished from the wiki while adding new stuff. will put it back
(2012-10-10, 23:19)`Black Wrote: Window.property works just fine if it's used in the home window. In other windows you have to use window(home).property.
