mcborzu
Skilled Skinner
Not at first since I've always had that artwork, I just ran it now though. I was only missing a few extrafanrts cuz not all my shows I had 5 extafanarts...
After running still cant get logo/clearart/landscape to show...
Check out Night - A Skin For XBMC
Hitcher
Team-Kodi Member
Because Episode != TV Show.
Kib
Team-Kodi Member
Hitcher, do you mean to say that an episode can also have its own clearlogo in the database ?
2013-01-30, 18:08
(This post was last modified: 2013-01-30, 18:09 by Martijn.)
Because i follow xbmc naming convention
mcborzu
Skilled Skinner
Can anyone 2x check the $INFO[Window(home).Property(RecentEpisode.1.Art(tvshow.clearlogo))] to see if works, I'm still getting nothing...
Incoming update in repo: see change log
2013-01-31, 02:16
(This post was last modified: 2013-01-31, 02:17 by Wanilton.)
Hi Martijn, thanks for great work, your addon is fantastic and very fast.
Please, add support for MPAA
I think is good have MPAA info in home and not start inapropriate movies for childrens,
I am using Aeon Nox, and translate skin for portuguese (Brazil). And of course use Skin Ace too...
Wanilton
Thanks Martijn, in change log don´t have info about my request, but in your code have mpaa field for movies,
Thank you,
Wanilton
