The TVDB scraper is currently broken due to upgrade works at TheTVDB site. We hope this issue will be resolved quickly.
[RELEASE] RadioReference.com Police Scanner for XBMC
Star
The XBMCHUB.com Team Presents...
RADIOREFERENCE.COM POLICE SCANNER FOR XBMC
Listen to Police, Fire and Emergency Radio Audio from Around the World with XBMC. Choose the Desired Geographical Location and Enjoy!
Installation
1. Install our Repo from ZIP file.
2. Enable the "RadioReference.com" Addon under "Music Addons"
Special thanks to tvalacarta for his awesome work and of course to the XBMC Foundation for everything!
Changelog:
Version 1.0.0
- Initial Release
Version 1.0.1
- Fixed Error in Windows
Version 1.0.2
- Fixed Issue with Quartz Skin
Have Fun! Wink
Thank you sir Smile
I hope you like it.
I'm sure the entire XBMC community will.
Great plugin, 1.0.1 works great!
Thanks bud, we're glad to be of service.
getting error on both windows 8 and appletv2 "addon.py" error at start of the plugin. any ideas thanks Kobyboy
Please post your error log, if you don't know how to do this, here's how: http://www.xbmchub.com/blog/2012/05/07/p...rror-logs/
(2012-11-09, 20:19)kobyboy Wrote: getting error on both windows 8 and appletv2 "addon.py" error at start of the plugin. any ideas thanks Kobyboy
Yes, please, post the log file so i can take a look.
There is no addon.py file in the add-on...
hi,
I'm getting script error: failed plugin Radio Reference.
Here are my logs Xbmc debug log & xbmc crashlog
Ops, never tested it with that skin.
Thanks for reporting, it will be fixed soon.
Please hurry! I'm anxious to try out this app. Thank you for all your hard work!
LOL! Wel I guess I could just change skins for now to see which one works.
It will be fixed shortly, the more logs we get the better we'll be able to make our addons. Thank you very much for your support.
Won't launch here either. Running a GIT nightly with metropolis skin and getting script failed error.
Quote:11:23:38 T:3007043392 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.audio.radioreference/?filter)
11:23:38 T:3007043392 DEBUG: ParentPath = [addons://sources/audio/]
11:23:38 T:2799696704 DEBUG: StartScript - calling plugin RadioReference.com('plugin://plugin.audio.radioreference/','0','?filter')
11:23:38 T:2799696704 INFO: initializing python engine.
11:23:38 T:2799696704 DEBUG: new python thread created. id=11
11:23:38 T:2799696704 DEBUG: WaitOnScriptResult - waiting on the RadioReference.com plugin...
11:23:38 T:2927622976 NOTICE: Thread XBPyThread start, auto delete: false
11:23:38 T:2927622976 DEBUG: Python thread: start processing
11:23:38 T:2927622976 NOTICE: -->Python Interpreter Initialized<--
11:23:38 T:2927622976 DEBUG: Process - The source file to load is /home/xbmc/.xbmc/addons/plugin.audio.radioreference/default.py
11:23:38 T:2927622976 DEBUG: Process - Setting the Python path to /home/xbmc/.xbmc/addons/plugin.audio.radioreference:/home/xbmc/.xbmc/addons/script.module.xbmcswift/lib:/home/xbmc/.xbmc/addons/script.module.t0mm0.common/lib:/home/xbmc/.xbmc/addons/script.module.cryptopy/lib:/home/xbmc/.xbmc/addons/script.module.demjson/lib:/usr/local/share/xbmc/addons/weather.wunderground/resources/lib/wunderground:/usr/local/share/xbmc/addons/script.module.simplejson/lib:/home/xbmc/.xbmc/addons/script.module.beautifulsoup/lib:/usr/local/share/xbmc/addons/script.module.pil/lib:/home/xbmc/.xbmc/addons/script.common.plugin.cache/lib:/home/xbmc/.xbmc/addons/script.module.simple.downloader/lib:/home/xbmc/.xbmc/addons/script.module.coveapi/lib:/home/xbmc/.xbmc/addons/script.module.free.cable.database/lib:/home/xbmc/.xbmc/addons/script.module.buggalo/lib:/home/xbmc/.xbmc/addons/script.module.mechanize/lib:/home/xbmc/.xbmc/addons/script.module.parsedom/lib:/home/xbmc/.xbmc/addons/script.module.elementtree/lib:/usr/local/share/xbmc/addons/script.module.pysqlite/lib:/home/xbmc/.xbmc/addons/script.module.metahandler/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PIL:/usr/lib/python2.7/dist-packages/gtk-2.0:/usr/lib/pymodules/python2.7:
11:23:38 T:2927622976 DEBUG: Process - Entering source directory /home/xbmc/.xbmc/addons/plugin.audio.radioreference
11:23:38 T:2927622976 DEBUG: Instantiating addon using automatically obtained id of "plugin.audio.radioreference" dependent on version 2.0 of the xbmc.python api
11:23:38 T:2927622976 NOTICE: [config.py] xbmceden config
11:23:38 T:2927622976 NOTICE: [config.py] runtime path = /home/xbmc/.xbmc/addons/plugin.audio.radioreference
11:23:38 T:2927622976 NOTICE: [config.py] data path = /home/xbmc/.xbmc/userdata/addon_data/plugin.audio.radioreference/
11:23:38 T:2927622976 NOTICE: [config.py] temp path = /home/xbmc/.xbmc/temp/test
11:23:38 T:2927622976 NOTICE: [launcher.py] run
11:23:38 T:2927622976 NOTICE: [launcher.py] extract_parameters
11:23:38 T:2927622976 NOTICE: [launcher.py] sys.argv=['plugin://plugin.audio.radioreference/', '0', '?filter']
11:23:38 T:2927622976 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: dictionary update sequence element #0 has length 1; 2 is required
File "/home/xbmc/.xbmc/addons/plugin.audio.radioreference/default.py", line 203, in <module>
run()
File "/home/xbmc/.xbmc/addons/plugin.audio.radioreference/default.py", line 21, in run
params, channel_name, title, fulltitle, url, thumbnail, plot, action, server, extra, subtitle, category, show, password = extract_parameters()
File "/home/xbmc/.xbmc/addons/plugin.audio.radioreference/default.py", line 115, in extract_parameters
params = dict(part.split('=') for part in sys.argv[ 2 ][ 1: ].split('&'))
ValueError: dictionary update sequence element #0 has length 1; 2 is required
11:23:38 T:2927622976 INFO: Python script stopped
11:23:38 T:2927622976 DEBUG: Thread XBPyThread 2927622976 terminating
11:23:38 T:2799696704 DEBUG: WaitOnScriptResult - plugin exited prematurely - terminating
(2012-11-14, 00:33)hazeleye65 Wrote: Please hurry! I'm anxious to try out this app. Thank you for all your hard work!
A new update 1.0.2 has been launched, fixing the Quartz skin problem Smile
(2012-11-19, 21:26)Aenima99x Wrote: Won't launch here either. Running a GIT nightly with metropolis skin and getting script failed error.
Mmm, a strange error.
Please try the 1.0.2 update to see if it fixes something.
  • 1 Vote(s) - 5 Average
[RELEASE] RadioReference.com Police Scanner for XBMC51
