No disk space - Timeshift on network share
Question
Hello, I'm stuck setuping the pvr xmbc with mediaportal tv server
All my recordings and timeshift are setuped to save on my NAS. MediaPortal does not seem to be able to write on the network drive and I can't find a way to give him permissions. Always have an error no disk space. Tried to save straight to an usb connected, it worked but it's lagging like hell!
Any suggestions?
*I'm on Win8, the tvserver is install on this same machine that xbmc.
Finally got it working by going in the services.msc and changing the TV Service (mediaportal tv server) and I set the log on user to be my admin user, took several try but finally got it working. Now the tv seems to be working fine in the MediaPortal front end but it it still lagging and not working well in XBMC through the addon found here http://www.dotnetdevelopers.net/XBMC/xbmcpvr.html
All settings in XBMC are the default one. I have no clue what else I should change or check?!
No clue either. What do you mean with lagging? Stuttering or buffering at the XBMC side?
What happens if you pause for e.g. 10 s and then continue playback. Is the playback still not smooth?
Enable debug logging in XBMC and check your xbmc.log file for MediaPortal pvr addon messages.
Developer of the MediaPortal PVR addon and retired developer of the Argus-TV PVR-addon.
http://www.scintilla.utwente.nl/~marcelg/xbmc
Found that I needed to set the user/pass in xbmc also, even if I though that setting it on the TvService was enough. Anyways. here's a new log. It is still lagging even if I set the credentials
And here's a video of what's happening: http://www.youtube.com/watch?feature=pla...3SNG6jZhaM
I guess this could help. It's my Xbmc log file
18:56:43 T:412 ERROR: CAESinkWASAPI::Initialize: WASAPI initialization failed.
18:56:35 T:2808  NOTICE: Thread CDVDPlayer start, auto delete: false
18:56:35 T:2808  NOTICE: Creating InputStream
18:56:35 T:2808   DEBUG: PVRManager - PVR::CPVRManager::OpenLiveStream - opening live stream on channel 'CKMI-HD'
18:56:35 T:2808   DEBUG: opening live stream for channel 'CKMI-HD'
18:56:35 T:2808   DEBUG: AddOnLog: MediaPortal PVR Client: ->OpenLiveStream(uid=7)
18:56:35 T:3716   DEBUG: ------ Window Init (DialogBusy.xml) ------
18:56:41 T:3716   DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
18:56:41 T:2808   DEBUG: AddOnLog: MediaPortal PVR Client: CVTPTransceiver::ReadResponse - timeout waiting for response, retrying... (6)
18:56:41 T:3716    INFO: XCURL::DllLibCurlGlobal::CheckIdle - Closing session to http://feeds.feedburner.com (easy=03DC8DF0, multi=018161E8)
18:56:42 T:2808    INFO: AddOnLog: MediaPortal PVR Client: Channel stream URL: rtsp://192.168.1.103/stream2.0, timeshift buffer: \\WEBZTEK\video\RECORDED_TV\_buffer\live2-0.ts.tsbuffer
18:56:42 T:2808    INFO: AddOnLog: MediaPortal PVR Client: Creating a new TsReader...
18:56:42 T:2808  NOTICE: AddOnLog: MediaPortal PVR Client: CTsReader::Open(\\WEBZTEK\video\RECORDED_TV\_buffer\live2-0.ts.tsbuffer)
18:56:42 T:2808   DEBUG: AddOnLog: MediaPortal PVR Client: FileReader::OpenFile() Trying to open \\WEBZTEK\video\RECORDED_TV\_buffer\live2-0.ts.tsbuffer
18:56:42 T:2808    INFO: AddOnLog: MediaPortal PVR Client: FileReader::OpenFile() \\WEBZTEK\video\RECORDED_TV\_buffer\live2-0.ts.tsbuffer.
18:56:42 T:2808   DEBUG: AddOnLog: MediaPortal PVR Client: FileReader::OpenFile: OpenFile(\\WEBZTEK\video\RECORDED_TV\_buffer\live2-0.ts.tsbuffer) succeeded.
18:56:42 T:2808   DEBUG: PVRFile - XFILE::CPVRFile::Open - playback has started on filename pvr://channels/tv/All TV channels/6.pvr
18:56:42 T:2808   DEBUG: CDVDInputStreamPVRManager::Open - stream opened: pvr://channels/tv/All TV channels/6.pvr
18:56:42 T:2808  NOTICE: Creating Demuxer
18:56:42 T:2808   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avutil-51.dll)
18:56:42 T:2808   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avcodec-53.dll)
18:56:42 T:2808   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avformat-53.dll)
18:56:42 T:2808   DEBUG: AddOnLog: MediaPortal PVR Client: FileReader::OpenFile() Trying to open \\WEBZTEK\video\RECORDED_TV\_buffer\live2-0.ts.tsbuffer1.ts
18:56:42 T:2808    INFO: AddOnLog: MediaPortal PVR Client: FileReader::OpenFile() \\WEBZTEK\video\RECORDED_TV\_buffer\live2-0.ts.tsbuffer1.ts.
18:56:42 T:2808   DEBUG: AddOnLog: MediaPortal PVR Client: FileReader::OpenFile: OpenFile(\\WEBZTEK\video\RECORDED_TV\_buffer\live2-0.ts.tsbuffer1.ts) succeeded.
18:56:42 T:2808   DEBUG: CDVDDemuxFFmpeg::Open - avformat_find_stream_info starting
18:56:43 T:2808   DEBUG: CDVDDemuxFFmpeg::Open - av_find_stream_info finished
18:56:43 T:2808    INFO: ffmpeg[AF8]: Input #0, mpegts, from 'pvr://channels/tv/All TV channels/6.pvr':
18:56:43 T:2808    INFO: ffmpeg[AF8]:   Duration: 00:00:06.44, start: 0.080978, bitrate: 14811 kb/s
18:56:43 T:2808    INFO: ffmpeg[AF8]:   Program 137
18:56:43 T:2808    INFO: ffmpeg[AF8]:     Stream #0:0[0x30]: Video: mpeg2video (Main) ([2][0][0][0] / 0x0002), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 24000 kb/s, 29.97 fps, 29.97 tbr, 90k tbn, 59.94 tbc
18:56:43 T:2808    INFO: ffmpeg[AF8]:     Stream #0:1[0x40](eng): Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, 5.1(side), s16, 384 kb/s
18:56:43 T:2808    INFO: ffmpeg[AF8]:     Stream #0:2[0x41](eng): Audio: ac3 ([129][0][0][0] / 0x0081), 48000 Hz, stereo, s16, 192 kb/s
18:56:43 T:2808  NOTICE: Opening video stream: 0 source: 256
18:56:43 T:2808  NOTICE: Creating video codec with codec id: 2
18:56:43 T:2808   DEBUG: CDVDFactoryCodec: compiled in hardware support: CrystalHD:yes DXVA:yes
18:56:43 T:2808   DEBUG: FactoryCodec - Video:  - Opening
18:56:43 T:2808   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/swscale-2.dll)
18:56:43 T:2808   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/swresample-0.dll)
18:56:43 T:2808   DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avfilter-2.dll)
18:56:43 T:2808  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: MPEG-2 video
18:56:43 T:2808   DEBUG: FactoryCodec - Video: ff-mpeg2video - Opened
18:56:43 T:2808  NOTICE: Creating video thread
18:56:43 T:2808  NOTICE: Opening audio stream: 1 source: 256
18:56:43 T:2808  NOTICE: Finding audio codec for: 86019
18:56:43 T:2808   DEBUG: FactoryCodec - Audio: passthrough - Opening
18:56:43 T:2808   DEBUG: FactoryCodec - Audio: passthrough - Opened
18:56:43 T:2808   DEBUG: CDVDPlayerAudio: Sample rate changed, checking for passthrough
18:56:43 T:2808  NOTICE: Creating audio thread
18:56:43 T:1216  NOTICE: Thread CDVDPlayerVideo start, auto delete: false
18:56:43 T:1216  NOTICE: running thread: video_thread
18:56:43 T:1216   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
18:56:43 T:2808   DEBUG: CDVDPlayer::SetCaching - caching state 2
18:56:43 T:420  NOTICE: Thread CDVDPlayerAudio start, auto delete: false
18:56:43 T:420  NOTICE: running thread: CDVDPlayerAudio::Process()
18:56:43 T:1216   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(205144.222222, 1)
18:56:43 T:1216    INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
18:56:43 T:1216   DEBUG: DXVA - supports 'MPEG2 VLD'
18:56:43 T:1216   DEBUG: DXVA - supports 'MPEG2 IDCT'
18:56:43 T:1216   DEBUG: DXVA - supports 'H.264 VLD, no FGT'
18:56:43 T:1216   DEBUG: DXVA - supports 4245F676-2bbc-4166-a0bb-54e7b849c380
18:56:43 T:1216   DEBUG: DXVA - supports 6719B6FB-5cad-4acb-b00a-f3bfdec38727
18:56:43 T:1216   DEBUG: DXVA - supports 9901CCD3-ca12-4b7e-867a-e2223d9255c3
18:56:43 T:1216   DEBUG: DXVA - supports 'VC-1 VLD'
18:56:43 T:1216   DEBUG: DXVA - supports CA15D19A-2b48-43d6-979e-7a6e9c802ff8
18:56:43 T:1216   DEBUG: DXVA - supports 7C74ADC6-e2ba-4ade-86de-30beabb40cc1
18:56:43 T:1216   DEBUG: DXVA - supports 5B23D46D-fa5f-4fdc-b78a-7eb2787942ec
18:56:43 T:1216   DEBUG: DXVA - supports D79BE8DA-0cf1-4c81-b82a-69a4e236f43d
18:56:43 T:1216   DEBUG: DXVA - supports F9AACCBB-c2b6-4cfc-8779-5707b1760552
18:56:43 T:1216   DEBUG: DXVA - supports ED418A9F-010d-4eda-9ae3-9a65358d8d2e
18:56:43 T:1216   DEBUG: DXVA - supports 103473E4-10ea-11df-9a92-2ba055d89593
18:56:43 T:1216   DEBUG: DXVA - supports 725AD240-786c-471e-ad3c-38f739936517
18:56:43 T:1216   DEBUG: DXVA - supports 00000000-0000-0000-0000-000000000000
18:56:43 T:1216   DEBUG: Previous line repeats 2 times.
18:56:43 T:1216   DEBUG: DXVA - trying 'MPEG2 VLD'
18:56:43 T:1216   DEBUG: DXVA - source requires 1 references
18:56:43 T:1216   DEBUG: DXVA - config 0: bitstream type 1
18:56:43 T:1216   DEBUG: DXVA - config 1: bitstream type 1, encrypted
18:56:43 T:1216   DEBUG: DXVA - allocating 8 surfaces
18:56:43 T:420   DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(21333.111111, 0)
18:56:43 T:420    INFO: CAEStreamInfo::SyncAC3 - AC3 stream detected (6 channels, 48000Hz)
18:56:43 T:420   DEBUG: CDVDPlayerAudio: Sample rate changed, checking for passthrough
18:56:43 T:420   DEBUG: FactoryCodec - Audio: passthrough - Opening
18:56:43 T:420   DEBUG: FactoryCodec - Audio: passthrough - Opened
18:56:43 T:420  NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, pass-through)
18:56:43 T:420    INFO: CSoftAE::MakeStream - AE_FMT_AC3, 48000, RAW,RAW
18:56:43 T:412   DEBUG: CSoftAE::Run - Sink restart flagged
18:56:43 T:412    INFO: CSoftAE::InternalOpenSink - RAW passthrough enabled
18:56:43 T:412   DEBUG: CAESinkWASAPI::IsCompatible: Formats Incompatible due to different :Sample Rates:Data Formats:Passthrough Formats
18:56:43 T:412    INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
18:56:43 T:412    INFO: CAESinkWASAPI::Initialize: Could not Initialize Exclusive with that format
[color=#FF0000][b]18:56:43 T:412   ERROR: CAESinkWASAPI::Initialize: WASAPI initialization failed.[/b][/color]
18:56:43 T:412   DEBUG: CSoftAE::InternalOpenSink - NULL Initialized:
18:56:43 T:412   DEBUG:   Output Device : HDMI - Digital Audio (HDMI) (High Definition Audio Device)
18:56:43 T:412   DEBUG:   Sample Rate   : 48000
18:56:43 T:412   DEBUG:   Sample Format : AE_FMT_S16NE
18:56:43 T:412   DEBUG:   Channel Count : 2
18:56:43 T:412   DEBUG:   Channel Layout: RAW,RAW
18:56:43 T:412   DEBUG:   Frames        : 24000
18:56:43 T:412   DEBUG:   Frame Samples : 2
18:56:43 T:412   DEBUG:   Frame Size    : 4
18:56:43 T:412   DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 96000
18:56:43 T:420   DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
18:56:43 T:2808   DEBUG: CDVDPlayer::HandleMessages - player started 1
18:56:43 T:3716   DEBUG: ------ Window Init (DialogSeekBar.xml) ------
18:56:43 T:2808   DEBUG: set caching from pvr to done. audio (1) = 12. video (1) = 13
Here's how it looks now. Lots of pixelization on some channels
http://youtu.be/a9F9s3jETQQ?hd=1&t=20s
At least I can see something now ..
what a choice of program to display your problem, all flashing and colors, and filming tv with a mobile ?? Big Grin
I don't notice any pixelation, but it seems like you didn't turn on deinterlace in video playback option.
(2012-11-22, 18:37)KRA77 Wrote: what a choice of program to display your problem, all flashing and colors, and filming tv with a mobile ?? Big Grin
Was quicker to upload than HD video with my cam.
Just watch Christina's leg.. it's pretty ugly Sad
yeah, that is not what I would call pixelation, it looks like de-interlace issue. Is it turned on ?
I'll take a look as soon as I get home. Is it supposed to be turned on or not? I remember having seen more than one option on interlace I think.. I'll confirm soon.
Thanks for the heads up!
No disk space - Timeshift on network share0
