  • 2(current)
  • 10
Globo.tv Addon [Brazilian TV Show producer]
#16
(2012-12-26, 14:11)vhd90 Wrote:
(2012-12-25, 21:00)ls84 Wrote: Any way to build-in an authentication step to watch pay content more fluidly?
Sure, there's a new version on the way supporting authentication.
I will post here once I get it done!
@ls84, just to let you know that a new version is available which supports user authentication
check it out on the first post, I've updated the info there
(2013-01-05, 06:57)gts02 Wrote: @vhd90 you rock!! I've been waiting for this for so long! Thank you so so much! Smile
@gts02, glad you liked it Smile
Hi vhd90!
First of all, thank you for this!
I'm testing your plugin on my Frodo.
Sometimes it shows an error message: "Erro: falha no plugin globo.tv" or "Erro: falha no plugin blabla.cache".
When cache error message shows up, the Opening Signal (Abrindo Sinal) get stucked. If you press Cancel, XBMC restarts (only the application).
Also, the video lenght is not showing right (or not showing). It rounds to 1 minute, 2 minutes, etc. And others just don't show.
It would be great if there's an option to show more than 10 vídeos per page.
Thank you!
@nerdjgua
Sure, glad you liked it Wink
I'm not currently using Frodo yet, so I may fall short on this.
Anyhow, could you enable the debug on the plugin settings and put the log up on pastebin or somewhere else so I could take a look?
Also give me a real example on the length, like what video are you seeing this issue.
Regarding videos per page, I'll add an option for the next release.
Cheers
everyone, just uploaded 0.5 at http://vitorhirota.github.com/plugin.video.globotv
fixes:
- 'skipping unplayable item' errors, which skipped every first item of playlists
- authorization issues for exclusive content, which made the plugin stream only in low def
- cases in which 'apparently no video worked' was probably due to unhandled m3u playlists being fetched, which was using relative paths to globo servers, these are filtered out now
Hi all
vhd90, thank you very much for share this plugin video with us.
regards
cenahum
Can someone please help with this stream. Thanks
http://www.multitvworld.com/newworld/
Thank you very much for this. My wife is learning Portuguese and this is great.
Thanks a million for this. I'm new to XBMC, but this was very easy to set up for my Brazilian wife. She loves her novelas! Been recording them on Dish Network, but Globo Internacional is SD only. Appreciate the available HD streams!
Hi
Two questions.
1) May seem dumb, but I can't even launch the application after un-zipping the folder and putting it in the add-on folder in AppData. Help? Keep getting a script error...
2) I know Globo is one thing, but is there a chance for an add-on for a PFC stream in the future? I know it's a long shot, but if I had that channel for Brasileiro, I would be almost in heaven Smile
first off, thanks for all the feedback guys
really appreciated.
(2013-02-28, 21:49)barca888 Wrote: 1) May seem dumb, but I can't even launch the application after un-zipping the folder and putting it in the add-on folder in AppData. Help? Keep getting a script error...
Turn on the debug and post a gist with the log so I can have a look.
(2013-02-28, 21:49)barca888 Wrote: 2) I know Globo is one thing, but is there a chance for an add-on for a PFC stream in the future? I know it's a long shot, but if I had that channel for Brasileiro, I would be almost in heaven Smile
Sorry, I personally don't know of any official online stream for PFC. If you do know, send it over via PM and I can take a look at it.
http://pastebin.com/HtCfCbTp
If you need more of the log, just let me know. Sorry, have never posted a log before...
Anyways, PFC officially streams at:
http://premierefc.com/
But being an American, obviously don't have access to Sky and therefore, can't access. I know:
http://www.dishworld.com/packages/brazil...-tv-globo/
is offered. But have heard of spotty coverage. All in all, was just wondering if anyone had a constant stream. Doesn't appear so though Sad
Thanks in advance.
Regarding your error, since you apparently installed it manually, XBMC couldn't check for dependencies. I suggest you install it through GUI via 'Install from zip file'
For PFC, don't have SKY either.
Even if I do write a plugin you would still need to be a subscriber, so no donuts for you then. Sorry.
And since I'm in Brazil, like yourself and SKY, don't thing I would have access to dish networks.
I'll keep a note here though, and keep checking.
Maybe in the future, PFC Online might be extended for other cable providers or who knows, an individual plan.
Installing through the GUI worked perfectly. Thanks again.
Hi all, installed it on my PC and works great. On the other hand, I have a Pivos Xios DS media player with the XBMC add-on (http://www.pivosgroup.com/xios.html) and it doesn't work. I actually causes the unit to freeze and I have to hard reboot it. Any ideas?
Cheers
(2013-03-09, 21:20)ChicoCanada Wrote: Hi all, installed it on my PC and works great. On the other hand, I have a Pivos Xios DS media player with the XBMC add-on (http://www.pivosgroup.com/xios.html) and it doesn't work. I actually causes the unit to freeze and I have to hard reboot it. Any ideas?
Cheers
The XBMC you are using in this Pivos is the regular Android release? If you can post a log on gist/pastebin, would be helpful...
  • 2(current)
  • 10
Globo.tv Addon [Brazilian TV Show producer]3
