Nogler
Junior Member
Is possible to add this code to master branch? Sorry i don't know how that get managed usually.
da-anda
Team-Kodi Member
2013-01-24, 02:32
(This post was last modified: 2013-01-24, 02:32 by da-anda.)
well, if you don't watch a 3D movie, turn 3D off. pieh/elupus implemented an action ("3dmode" IIRC) to cycle the 3D modes via your remote or keyboard by adjusting the keymap and bind a key/button with this action. I gave it a try a couple days ago and it worked just fine.
spmp
Junior Member
da-anda. With two projectors setup with twinview (et. al) overlapping, the duplicated gui is essential, in as much as without it XBMC fullscreen (without sbs gui) spans both projectors creating a big mess. I have never used/seen a 3d TV, can you set them to stereo at any tim?
The way things are setup for me there is no disabling 3D. (Hence the question is nontrivial in my case)
Amazing work Pieh! (and the rest of the XBMC team) what a slick proggy this is!
Youve even restircted the mouse, so good!
Stupid question perhaps, but is this patch intended to patch sourcecode before compiling it, or is it to patch ie a script in an already running system?
I'm running Xbian on my Raspberry PI and I'm very satisfied with it and the only thing I really miss, are subtitles for 3D movies.
fritsch
Team-Kodi Developer
Chuck Norris patches binaries all the day - but as you are not Chuck Norris, try patching the source before compiling.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
Hi guys,
I'm a little lost right now. All of my movies are Half-SBS or SBS, so which patch should a try on Frodo?
