da-anda
Team-Kodi Member
2013-05-25, 10:34
(This post was last modified: 2013-05-25, 10:36 by da-anda.)
as said - no detection tag editing in GUI. This is a advanced setting and as of now has to move there. Once we decide to add some of the advanced settings to the GUI this can be considered, but until then it has to go. We don't have any other of our regular expressions, file extensions or scraper settings in GUI and 3D file tag parsing stuff doesn't belong there neither.
Point is, the default setting should be as generic as possible and work for 99% of users, based on current scene standards. So there should be no need to edit that stuff, but could be done in edge cases.
@position of 3D settings
sorry, but stereoscopic 3D IMO is a subsection of the video output and not a top level section. Also parts of those settings are playback related and thus not really a global system setting, but I also don't want to split the 3D settings and move parts to several places. This needs some more thoughts.
Nogler
Junior Member
Why not place the extra settings in a python script?
da-anda
Team-Kodi Member
you don't have to remux - simply use the "header editor" of mkvtoolnix - two clicks and done.
None of the mkv 3d movies in my collection have 3d tags. Editing the movie name is much easier than remuxing.
Since now xbmc has various levels of user privileges, these settings can be moved to the advanced level. The 3d detecion tags can be added to a python script like the one by 'jaaps'.
Another feature I would like to have is flipping the frames. I have to completely recode a movie just because the left right frames were reversed.
elupus
Team-XBMC Developer
i pushed an updated branch a few minutes ago. fixed a bug with matroska internal 3d tag detection. you may want to rebase. It is also based on the code that will go into xbmc when we merge buffered rendering.
