3D on XBMC 13 ALPHA 7, windows.
hey, found a bug :
theres a problem with the audio output:
when on hdmi or optical mode, the 3d movie fast forwards wiith no sound,somewhere along the middle of the movie it sets up right.
when i change to analog the movie works fine.. hope for a fix soon.other then that subtitles work great!
szape
Junior Member
I have a problem: when XBMC detects the 3D movie and i select anaglyph (red/cyan) it plays in 2D, not anaglyph. Tried several movies but all plays in 2D.
nickr
Retired Team-Kodi Member
So are you saying that including .3dbd.sbs won't
(a) signal the skin that it is a 3d movie; and
(b) signal xbmc that it is a sbs movie?
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
Hmmm. only one way to find out I guess? I was just going by the documentation. I figured if they say that I must use a particular tag, that none others would work.
So apparently using .3dbd.ou does still trigger the skin, I guess having 3dbd in the tag somewhere is enough? I did have to remove and re scan the movie with the new .3dbd.ou tab into the library and it also removed the "watched" status... But I guess that is not such a bog deal as any new movies I add will no be affected like this.
I placed <stereoscopicflagstab>3dbd.ou</stereoscopicflagstab> in advanced settings.
However, Gotham did say "Playing in 2d monoscopic" when I started playing the movie, but it is still playing as split screen (only for the O/U movie with the .3dbd.ou tag). Clearly it recognized it as 3d, and it also attempted to play it in 2d, but I think it is still viewing it as a SBS as the video is still split top to bottom, but I can only see the left half of the movie. I'll have to mess around with it and see if I can fix this. Thanks for the help.
2013-09-17, 06:50
(This post was last modified: 2013-09-17, 06:54 by Dam0.)
um, if you are trying to watch a 3d H-SBS file in 2d mode, then that is what you will get...
in which case, xbmc is just playing the file, nothing fancy here... unless maybe subtitles and menus changing positions??.
if your display device supports hsbs/hou, and you manually set display to 3d, then you should get 3d effect with glasses etc, using the 2d mode.
at least that is my understanding of what the 3D functionality integrated within Master builds entails.
D.
I think your problem lies in the advancedsettings. You have defined 3dbd as sbs file and 3dbd.ou as tab file. In this case 3dbd.ou will be treated as sbs also.
da-anda
Team-Kodi Member
2013-09-17, 17:39
(This post was last modified: 2013-09-17, 17:40 by da-anda.)
szape - out of curiosity, what brand and model is your GPU? I suppose some older AMD with legacy drivers?
