OK, I managed to fix that problem by bumping up the wait time between pressing the 3D button and the OK button. Seems that 200ms was just far too quick for my TV to accept.
Now, fingers crossed it is working great, thank you for a great script!
2014-03-09, 12:47
(This post was last modified: 2014-03-09, 12:47 by brownbear1984.)
Don't thank me it was Jaaps' code i only added a few edits. I'll make that configurable. There is one bug I have left but I have no idea on how to fix it. Ive set it to turn off 3d when stop is pressed which works but it does it on sd movies too any ideas on how to fix?
Hmmm... I guess a flag could be set when the movie started, like "3Dmovieplaying=1", then on stop "if 3Dmovieplaying=1, then press 3d button". I don't know Python or how XBMC implements it, but would that work?
Yeah I thought that but when i tried to implement it it carried on going to 3d for normal movies i'll do some further testing and push my changes when i've figured it out.
Make sure to reset the flag to 0 when all is finished and I don't see why it wouldn't work.
Having a scaling issue when playing 3D files H-SBS. Using Openelec Gotham Beta on an AMD APU (E1-2100).
1080p files play fine.
1080p SBS files play fine.
When I play a file that XBMC thinks is 3D it looks terrible (it looks perfect if I just play the file with 3D off).
I see other people have had this problem but there was never a solution.
What is happening is XBMC is scaling half up then scaling it back down to half. (makes sense why it would do that).
This is working but the scaling is terrible. so it comes out all jaggedy.
I treid changing scaling methods and it had no effect.
Any ideas?
nickr
Team-Kodi Member
Have you calibrated video inside xbmc - that will screw up 3d.
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
da-anda
Team-Kodi Member
can you provide a sample of an affected movie or show us a screenshot? And can you test the same movies on a desktop version of XBMC (maybe it's OpenElec/driver related).
elupus
Team-XBMC Developer
What os is this on? Do you have any nonstandard scaling enabled?
