2014-03-18, 14:19
@elupups - read a few posts back on this page - he's using Openelec Gotham Beta on an AMD APU (E1-2100).
(2014-03-18, 15:53)elupus Wrote: And the scaling settings?
21:38:44 T:1416 NOTICE: GL_VENDOR = NVIDIA Corporation
21:38:44 T:1416 NOTICE: GL_RENDERER = GeForce GT 240M/PCIe/SSE2
21:38:44 T:1416 NOTICE: GL_VERSION = 3.3.0
21:38:44 T:1416 NOTICE: GL_SHADING_LANGUAGE_VERSION = 3.30 NVIDIA via Cg compiler
21:38:44 T:1416 NOTICE: GL_GPU_MEMORY_INFO_TOTAL_AVAILABLE_MEMORY_NVX = 1048576
21:38:44 T:1416 NOTICE: GL_GPU_MEMORY_INFO_DEDICATED_VIDMEM_NVX = 1048576
(2014-03-19, 18:43)toxwa Wrote: It would be nice that if XBMC detected it was a 3D movie, it would switch to the 1920x2205 resolution automatically. Now it detects a 3D movie, sets the interface to half over under and I have to manually set my tv to over ( and I loose half the resolution).
(2014-03-20, 17:11)bigbadrabbit Wrote:As already mentioned somewhere in here IIRC, this will be worked on, but it requires some internal refactoring to work properly (also has to work for midstream changes when thinking about PVR) and our main developer for this (elupus) is lacking time atm. And yes, it won't be available in Gotham. For the time being you can try the "hardware" 3D mode on supported platforms/drivers (linux and maybe OSX, no idea). It's also working on the PI using builds from MilhouseMV (up to a certain degree).(2014-03-19, 18:43)toxwa Wrote: It would be nice that if XBMC detected it was a 3D movie, it would switch to the 1920x2205 resolution automatically. Now it detects a 3D movie, sets the interface to half over under and I have to manually set my tv to over ( and I loose half the resolution).
I too have setup a resolution 1920x2205 and i have to manually switch to this one to get my projector in 3D-mode.
Would be really great if XBMC would switch automatically when starting a video and switch back to 1920x1080 when stopping it.
(2014-03-20, 17:22)da-anda Wrote:(2014-03-20, 17:11)bigbadrabbit Wrote:As already mentioned somewhere in here IIRC, this will be worked on, but it requires some internal refactoring to work properly (also has to work for midstream changes when thinking about PVR) and our main developer for this (elupus) is lacking time atm. And yes, it won't be available in Gotham. For the time being you can try the "hardware" 3D mode on supported platforms/drivers (linux and maybe OSX, no idea). It's also working on the PI using builds from MilhouseMV (up to a certain degree).(2014-03-19, 18:43)toxwa Wrote: It would be nice that if XBMC detected it was a 3D movie, it would switch to the 1920x2205 resolution automatically. Now it detects a 3D movie, sets the interface to half over under and I have to manually set my tv to over ( and I loose half the resolution).
