nickr
Team-Kodi Member
Works for me on linux, both in 3D and mono. Running Gotham.
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
Trupke
Junior Member
2014-08-05, 08:58
(This post was last modified: 2014-08-05, 08:58 by Trupke.)
Maybe update a rendering package or something, but what package should I update (if this could be the problem)?
da-anda
Team-Kodi Member
you're using your own custom build, right? So maybe check which package versions OE, Raspbian etc use and try with those? Can't give any other advice as I'm not at all a linux guy
da-anda
Team-Kodi Member
any other Xbian user having same issue? Have you asked in their forum?
Trupke
Junior Member
Have googled the issue, afaik I'm the only troubleseeker.
nickr
Team-Kodi Member
Grab another SD card and try openelec, you have nothing to lose.
nickr
Team-Kodi Member
We are trying to diagnose your 3D problem. Did the file work on openelec? That is the only question right now.
No one suggested a permanent move, merely trying to isolate the problem.
Trupke
Junior Member
Ok, I've tested it and:
- Clean Xbian install, left me with no different results, same squeezed video image.
- Clean OpenELEC install, problem solved.
What do you recommend to be my next step to get this problem solved?
da-anda
Team-Kodi Member
in case Kodi codebase is the same for both it could be different package versions of dependencies or maybe a borked firmware. But I can only guess and assume from what I've catched up here and there - not a dev.
da-anda
Team-Kodi Member
I'm not sure if popcornmix is following this thread, but he's your best bet, so probably head over to "General Help & Support" and report in the RasPI section.
