Edwrib
Junior Member
I'm trying to play half-ou in a Android Nvidia Tegra 3, my TV can combine the double-half screen to one, no issue at all if I need press a button in remote control, but my issue is that movie are being displayed like if they are 2D, in full screen.
I already tried to use only libstagefright, but I have the same results.
It's a bug in Kodi helix rc or Android can't display 2 images (to generate the 3D) while hw decoding?
AFAIK Kodi does not support hardware decoding of 3D's at all. Only software decoding (needs a CPU with a little muscle). Some people have reported some luck with external hardware.
nickr
Retired Team-Kodi Member
You and I have had this discussion in another thread, and I can't add any more. My comment in this thread was more aimed at wgstarks.
Perhaps the hardware or firmware in the tegra is too smart?
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
nickr
There are some reasonably short samples out on the net. Makes it easier to test than getting gigabytes of a full movie.
