jjd-uk
Team-Kodi Member
Apart from the 1st post, that thread is an exact copy of what was here until I posted above, any responses will be given on that Support Thread. Myself & the other moderators will be removing anything that's not a test report from this thread going forward.
Koying
Retired Team-Kodi Member
A Gotham alpha5 build has been added.
2013-07-03, 16:21
(This post was last modified: 2013-07-03, 16:23 by nero12.)
I dont know if this is any helpful, but i tested the Alpha5 today on my ouya box and i have the following feedback:
Yesterday there was a xbmc-20130701-* this release on ouya box had 1080p issues. (today this version is not available on the download page)
Today i see this version xbmc-20130703-* this version on ouya still has 1080p issue but 720p for me looks a bit better, but still noticeable stuttering. However on this version playback of rtmp links does not work, but on the 20130701 version it played fine, it throws me out of xbmc.... when i try enter it again it throws me out again , and only second time i can enter the box. by that time the log file and the oldlog file is deleted, so i guess i need to ssh into the box and get it instead.
the one recommended on xbmc ouya wiki - 1080p files works flawlessly, however this version has the same rtmp problem.
I got my ouya yesterday, so dont know much yet.. but if u need anything let me know, i can be of any help.
I hope your vacations were great Koying.
As you live in Brussels, i presume that you left it to get a little more heat and sun (i live in Lille ...).
Could you look to post 670, it describes a vertical lines issue with debug log that i can reproduce. As i cant provide a debug log (addon doenst works and i dont have a windows computer to get adb on my ouya) i put a sample of a ts file in post 663.
Hope it will help you,
slhpss
Junior Member
I can confirm on the odroid u2 rtmp plays in fast forward. There is another test build called droid rtmp fix but it has the same behavior.
Koying
Yeah, confirmed alpha5 is not working due to the bug mentioned by mo123.
2013-07-04, 09:42
(This post was last modified: 2013-07-04, 09:49 by solispg.)
I just tried the latest version released July 3, [UPDATE 3/07/2013] Updated Gotham alpha5, and it does not work on the Asus Memo Pad 172V tablet, which is 7". It does the same thing that the official XBMC app does, after it installs successfully, it begins first time startup process and finishes, then instead of loading the XBMC app, it kicks me out to the homescreen, with no error of any type. When I try clicking on the app again, it just sends me to my homescreen. If anyone has any suggestions or ideas, I would appreciate it, Thanks.
P.S. I have the official XBMC app running on my Samsung Galaxy Note 2 and it runs awesome, can't wait until I can get this tablet working on XBMC too.
