panni
Junior Member
I've restricted crosslinking of the files on the fragstore mirror to prevent traffic spikes. Always use the link to the .exe files from this thread.
2013-02-25, 00:53
(This post was last modified: 2013-02-25, 01:02 by technick.)
Hi, for your information.
- I bought DVBViewser 5 (15€) to use TV inside XBMC and it work perfectly ! I use a Dual TNT hdhomerun tuner and IP TV from my french provider Orange, I made a favorite list composed of a combination of these 2 source and It's that I use inside XBMC. Zapping is < 2 second :-) (was > 8 secondes with the Mediaportal TV server...)
- I use a Linux ubuntu server with samba for my videos and if I use LAV filter source I can play only 1 video, on the second play dsplayer made a graph error. If I use Haali source (with LAV decoders) all work fine (with the haali HD sounds limitation for sure) Note that the same LAV source filter work fine for video that are on locals HD !? The problem is only for videos on shares folders.
- I currently test this Advancedsettings.xml setting on my Nvidia card
<adjustrefreshrate>
<override>
<fps>23.976</fps>
<refresh>23</refresh>
</override>
</adjustrefreshrate>
because I discover that 23.976 video was played at 24...
I hope it can help someone ;-)
Technick
Does DSPlayer supports skipping of commercials using ComSkip generated chapter files, like original Frodo does?
hi technick,
can you explain me for the iptv settings for orange.
it doesn't seems to work at home.
thanks.
Please note that there was a major change introduced in the latest build. Video DB format is now compatible with standard Frodo builds, and DSplayer stores its own data in a separate DB. However, you may need to do Export/Import to migrate your Video Library to this build.
