  • 9
  • 10
  • 11(current)
  • 12
  • 13
  • 95
DSPlayer (DirectShow Player for XBMC) Frodo build available
thx panni
HTPC
Silverstone Grandia GD05 - Intel i5 3570k -Asus H61M-G Micro-ATX - Unidad Blu-ray
MSI GTX970 4GB GDDR5 - 8 GB RAM DDR3 - AVR Denon X3400H Atmos - LG  OLED 55C7V
(2013-03-21, 13:01)juro1971 Wrote: Does this mean, that ds player can not be used for tv?
Without going into too much explanation let's say that it does not support TV.
(2013-03-21, 16:31)tman12 Wrote: Any word on a 12.1 release?
12.1 code have just been released. Me or panni will post a compiled installer soon.
(2013-03-22, 01:18)panni Wrote: Based on http://git.avmedia.su/git/?p=xbmc.git;a=...326b8af426, 13/03/19: http://fragstore.net/panniweb/XBMCSetup-...d32-dx.exe
This commit seems a bit old.
12.1 code is here: http://git.avmedia.su/git/?p=xbmc.git;a=...12.1-Frodo
Eduard has also added support for iMON/VFD displays but don't ask about details.Smile I don't even know what does it mean beyond what I can find in Google.
So Panni's 13/03/19: http://fragstore.net/panniweb/XBMCSetup-...d32-dx.exe is not 12.1?
You can download XBMC DSPlayer 12.1 from Eduard's XBMC DSplayer page
http://xbmc.avmedia.su/
(2013-03-22, 15:07)oldpoem Wrote: You can download XBMC DSPlayer 12.1 from Eduard's XBMC DSplayer page
I'm not sure but that build could have been compiled with Russian on-screen keyboard patch. It still allows to input English characters but it supports Russian Cyrillic too.
Here I always post generic builds without locale-specific additions.
Eduard built 2 version.
Normal version & Custom built version
Custom built has virtual russian keyboard , russian repo etc.
For anyone who isn't Russian. Normal version would do just fine.
The first post still shows the old build. The last build I've posted was the newest build of the 12.0-Frodo head.
12.1 based on http://git.avmedia.su/git/?p=xbmc.git;a=...2ea8c7fc1b: http://fragstore.net/panniweb/XBMCSetup-...f2b-dx.exe
(2013-03-21, 13:01)juro1971 Wrote: 1. The xml configuration is not very comfortable. I had some sucess but at the end no video plays Confused
Are there any preconfigured xmls using lav splitter and lav video codecs in combination with ffdshow postprocessing for upscaling any sd video material? is postprocessing possible or only in combination using ffdshow video codecs
You can use my xml
http://dl.dropbox.com/u/45748725/DSPlayer%20Config.zip
copy mediaconfig, filtersconfig & renderersettings in %Username%\AppData\Roaming\XBMC\userdata\dsplayer\
and playercorefactory in C:\Users\XXX\AppData\Roaming\XBMC\userdata\
Of course you need to install LAVFilters , AV Splitter & FFDshow packages. Be sure to disable "Use system filters (DirectShow merits)".
You can use my xml
I will take a try , thanks
I have updated the 1-st post with the links to 12.1 build.
Note that I haven't tested it myself, so I cannot tell how it works.
Keep in mind that any XBMC for Win build can be launched in portable mode with -p command parameter, so you can have multiple XBMC instances each with its own settings, e.g. for testing purposes.
Good morning everyone.
Thanks for the excellent work he has done.
I need help, I can not make my MKV files use the filter lavvideo, I set up everything for it to be used, and can not use this filter, and the filter always used Microsoft DTV-DVD Video Decoder.
Thank you for your help, and sorry for my english by google translator.
Greetings
You can use my xml
Why av splitter, isn't LAV filters package enough?
After installing av spliiter packages works for mkv, dix, xvid as I expected :-) until i play a ddvd, dvd starts to play, ds playder did not start, standard player plays DVD, after playing a dvd no more movie can be played, I have to restart xmbc :-(
Can your configuration also be used for playing sd tv ?
(2013-03-23, 12:56)HTPCAsus Wrote: Good morning everyone.
Greetings
You need to disable "use directshow merit" option. That'd tell DSPlayer to use xml configuration.
(2013-03-23, 15:11)juro1971 Wrote: Why av splitter, isn't LAV filters package enough?
AV Splitter works with MKV /w chapters (like Haali Splitter) which LAV Splitter can't.
From my experience I prefer internal player to deal with DVD , TV & Stream. DSPlayer doesn't handle it well or doesn't work at all in some type. So I setup my config that way.
Thank you still can not use the filter lavvideo not know what's going on?!
(2013-03-23, 20:27)HTPCAsus Wrote: Thank you still can not use the filter lavvideo not know what's going on?!
OldPoem Wrote:You can use my xml
  • 9
  • 10
  • 11(current)
  • 12
  • 13
  • 95
DSPlayer (DirectShow Player for XBMC) Frodo build available8
