  • 22
  • 23
  • 24(current)
  • 25
  • 26
  • 95
DSPlayer (DirectShow Player for XBMC) Frodo build available
@vicmanpergar have you found that the best combination is LavFilter and Avsplitter?
(2013-08-26, 15:01)oldpoem Wrote:
(2013-08-26, 04:07)obelisk79 Wrote: I've tried following the russian guide to setting up svp with lav filters with the DSPlayer xbmc with no luck. Would anyone be so kind as to put together an easy to follow english guide for this? I'm still googling a comprehensive tutorial but not having the best of luck.
Install SVP and add ffdshow raw video filter in chain would do the trick. I used to set it up that way but not anymore.
@oldpoem, curious how do you set it up now; do you still use filters?
(2013-09-05, 06:46)zariaman Wrote: @vicmanpergar have you found that the best combination is LavFilter and Avsplitter?
Lavfilters and madvr are my favs
With XBMC i use LavFilters in combination with avsplitter due to the nice titles and menus options Eduard has implemented.
HTPC
Silverstone Grandia GD05 - Intel i5 3570k -Asus H61M-G Micro-ATX - Unidad Blu-ray
MSI GTX970 4GB GDDR5 - 8 GB RAM DDR3 - AVR Denon X3400H Atmos - LG  OLED 55C7V
What player are you using for madvr?
MPC-HC
HTPC
I switched to XBMC Nighlies for months.
Current 12.2 Frodo build based on http://git.avmedia.su/git/?p=xbmc.git;a=...58e163ce48: https://fragstore.net/dsbuilds/XBMCSetup...ce6-dx.exe
whoa im really suprised this is still being developed thanks for all the work done on this project i started 2 years ago
(2013-09-19, 03:26)panni Wrote: Current 12.2 Frodo build based on http://git.avmedia.su/git/?p=xbmc.git;a=...58e163ce48: https://fragstore.net/dsbuilds/XBMCSetup...ce6-dx.exe
I cannot reach fragstore.net Any other ways to download the setup? Thanks
I can't download either.
It's working alright.
But you need to enable passing the HTTP referer header to your download manager or browser, as panni (like he is saying here), has to enable that limitation to avoid bandwidth abuse from outsiders.
(2013-09-23, 21:56)Saxtus Wrote: It's working alright.
Too bad I don't know how to do that Sad
(2013-09-24, 01:54)NickoP Wrote: Too bad I don't know how to do that Sad
Easy: It's the default behavior of all major browsers.
If you haven't added a plug-in or changed a setting, then it must be your firewall.
Yeah just click the link here. If that doesn't work, try a clean profile or an anonymous tab. Or even a different browser for this particular time, as having the referer header enabled is default.
Hello.
About DSPlayer Frodo build.
A thumbnail is not displayed when a bookmark is created.
Is it a bug?
The following program was tested.
1)Post: #1 XBMCSetup-20130721-52b961a-dx (latest build)
2)Post: #1 Frodo 12.2 builds with PVR and 3D subtitles improvements(by Slurm)
3)Post: #352 XBMCSetup-20130908-6da6ce6-dx
and non DSPlayer
4)Latest Stable :XBMC 12.2 "Frodo" (of course, DSPlayer has no integration)
1,2,3) DSPlayer MODE (not displayed)
1,2,3) DVDPlayer MODE (not displayed)
4) XBMC 12.2 "Frodo" (displayed)
  • 22
  • 23
  • 24(current)
  • 25
  • 26
  • 95
DSPlayer (DirectShow Player for XBMC) Frodo build available8
