2013-09-05, 06:46
@vicmanpergar have you found that the best combination is LavFilter and Avsplitter?
(2013-08-26, 15:01)oldpoem Wrote:(2013-08-26, 04:07)obelisk79 Wrote: I've tried following the russian guide to setting up svp with lav filters with the DSPlayer xbmc with no luck. Would anyone be so kind as to put together an easy to follow english guide for this? I'm still googling a comprehensive tutorial but not having the best of luck.
Install SVP and add ffdshow raw video filter in chain would do the trick. I used to set it up that way but not anymore.
(2013-09-05, 06:46)zariaman Wrote: @vicmanpergar have you found that the best combination is LavFilter and Avsplitter?
(2013-09-09, 23:29)vicmanpergar Wrote:(2013-09-05, 06:46)zariaman Wrote: @vicmanpergar have you found that the best combination is LavFilter and Avsplitter?
Lavfilters and madvr are my favs
With XBMC i use LavFilters in combination with avsplitter due to the nice titles and menus options Eduard has implemented.
(2013-09-10, 03:02)zariaman Wrote:(2013-09-09, 23:29)vicmanpergar Wrote:(2013-09-05, 06:46)zariaman Wrote: @vicmanpergar have you found that the best combination is LavFilter and Avsplitter?
What player are you using for madvr?
(2013-09-09, 19:13)zariaman Wrote:(2013-08-26, 15:01)oldpoem Wrote:(2013-08-26, 04:07)obelisk79 Wrote: I've tried following the russian guide to setting up svp with lav filters with the DSPlayer xbmc with no luck. Would anyone be so kind as to put together an easy to follow english guide for this? I'm still googling a comprehensive tutorial but not having the best of luck.
@oldpoem, curious how do you set it up now; do you still use filters?
(2013-09-19, 03:26)panni Wrote: Current 12.2 Frodo build based on http://git.avmedia.su/git/?p=xbmc.git;a=...58e163ce48: https://fragstore.net/dsbuilds/XBMCSetup...ce6-dx.exe
(2013-09-23, 21:56)Saxtus Wrote: It's working alright.
But you need to enable passing the HTTP referer header to your download manager or browser, as panni (like he is saying here), has to enable that limitation to avoid bandwidth abuse from outsiders.
(2013-09-24, 01:54)NickoP Wrote: Too bad I don't know how to do that
