  • 42
  • 43
  • 44(current)
  • 45
  • 46
  • 95
DSPlayer (DirectShow Player for XBMC) Frodo build available
@Roman_V_M
the branch "master" from eduard's repo that automatically merge with the official master i think that it's just a copy, because there is not trace of dsplayer into it
http://git.avmedia.su/git/?p=xbmc.git;a=...ads/master
instead in the branch "dsplayer" the merging is stop to alpha3 as you can see here http://git.avmedia.su/git/?p=xbmc.git;a=...s/dsplayer
VALUE "CompanyName", "Team XBMC"
            VALUE "FileDescription", "XBMC"
            VALUE "FileVersion", "13.0-ALPHA3"
            VALUE "InternalName", "XBMC.exe"
            VALUE "LegalCopyright", "Copyright (c) Team XBMC.  All rights reserved."
            VALUE "OriginalFilename", "XBMC.exe"
            VALUE "ProductName", "XBMC for Windows"
            VALUE "ProductVersion", "13.0-ALPHA3"
i don't know if this code work or not, anyway i was trying to update this source to gotham alpha4 to procede step by step Smile
but there is alot of differences because this commit
"settings: integrate new settings system into GUI"
with this new system of GUI i missing totally the way to procede, because i don't know how work the entire integration of dsplayer
I should to study everything from the beginning
too much for me Smile
hello guys
I tried and tried to apply DSPlayer into source of Gotham Beta1
and finally I've done it
certainly not everything worked, because eduard has added a lot of things and the menu in the version of DSPlayer and have not yet managed to make it all work
But compile everything without errors is a first step
in menu systeminfo appears as build 12.2 git etc etc, I do not know how work the git's variables etc etc, but I assure you that the dsplayer was added on the source of gotham beta1
you just have to set in the folder userdata/DSPlayer the filters as usual
I repeat, is only a first step ... then maybe eduard can came back to help us to complete everything
for now i've place the "exe only" build of gotham beta1 with dsplayer ...
in the meantime i do a cleaning of my source and i try to figure out how to use github
http://www.mediafire.com/download/e7u7xk...xeonly.rar
Great job aracnoz! Big Grin
For troubleshooting and bug reporting please make sure you read this first.
@aracnoz, the exe linked won't open - error message "python27.dll" missing from your computer.
@steelman1991
you must first install xbmc-13.0-Gotham_beta1.exe
and then replace the exe file in the folder
P.S.
for everybody
do not expect that everything works perfectly
is a small first step
there is no main menu of DSPlayer yet
to launch a file with DSPlayer you have to do
play using ... DSPlayer
Ah I get now aracnoz - thanks for that. Good first step though.
ok i think i've done with github
source: https://github.com/aracnoz/xbmc/tree/Got...1_dsplayer
win32build: http://www.mediafire.com/download/ofxf13...xeonly.rar
Unfortunately I do not have much time to work as I want, but I think it's a pretty big first step
I would like to provide suggestions if anyone would like to continue the work
the things that needed to be fixed starting from the integration of DSPlayer in this file "GUIWindowSettingsCategory"
now in gotham is totally different so you have to study this a little
then there is the method GUIWindowsVideoBase::MarkWatched That has moved to GUIDialogVideoInfo :: markwatched
something to fix in stdstring.h and GUIDialogPlayerControls
and then who knows...
my priority was to compile without error to start the project
ciauzz
EDIT:
I figured out how to work the new method of gui "GUIWindowSettingsCategory"
so I added the DSPlayer's menu
i've updated the link to the exe build, in the archive there are files that are necessary to see the menu... so they must be replaced
the directshow's filters seem to be loaded correctly in the xbmc.log
but the videoplayback stutter
i think that i need a hand for this :\
ciauuz
Will this mean that tiben20 could work on MadVR integration basing his work on Gotham, instead of Frodo?
(2014-03-10, 19:34)aracnoz Wrote: but the videoplayback stutter
Im looking into it, im kinda stock with madvr right now so maybe doing something else will help me
@ashlar
maybe when the integration of dsplayer is more stable Smile
...some update
this is latest build: http://www.mediafire.com/download/s8jqxu...xeonly.rar
I finished adding all the code from the eduard's repo in gotham_beta1
there are the lists of dsplayer's filter in the menu of the playercontrol
and the render stats
the problem with the stutter it's still there... maybe something it's changed in the way that cdvdplayer (cdsplayer in our case) send information to initializate the playback
because in the stats the information are all there, but the real fps is stuck on 8fps
but when you put the video in background, the stuttering goes away but there's still something wrong in the playback stats
seem that with video in background the playback use the framerate that use the interface
so then goes more smoothly, but I do not think he uses the right framerate of the video
anyway here some screenshots
gotham dsplayer in fullscreen
gotham dsplayer with video in background
frodo dsplayer in fullscreen
things todo for now
- resolve video stuttering Smile
- send label information to osd
and fix something in dsplayer table creation
@tiben20
thanks for help Smile
ok guys
stuttering problem it's fixed thx to @tiben20
in 5 min he has found e solve the problem, shame on me Smile
there is some small fixes to do in the stats report but the platback now it's smooth
the build: http://www.mediafire.com/download/frhp94...xeonly.rar
night
ciauzz
he is lying took me at least 30 min to figure it out
Nice works! Really appreciates all efforts put in DSPlayer recently.
@aracnoz seem like subtitles aren't working in DSPlayer for Gotham both internal and external.
My humble suggestion is not to fragment the project and create a single public repo on Github so that everyone could have access to the code and work with it in a single place.
E.g. I'm not a developer but I create and use custom builds with English/Cyrillic on-screen keyboard.
Good job guys Big Grin
As well as the subs, pressing i in play mode is not show movie info etc.
K
Sapphire RX 5700 XT (19.9.2)  Ryzen 7 3700x, PRIME X570-Pro, Win 10 x64 (1903), Silverstone LC13B-E, Onkyo TX-RZ800, LG OLED55BX6LB, Mission M35i speakers, Kodi Dsplayer 17.6 X64
  • 42
  • 43
  • 44(current)
  • 45
  • 46
  • 95
DSPlayer (DirectShow Player for XBMC) Frodo build available8
