That sounds good. How do you configure Xy-SubFilter? During playback?
i'm done, and i will hope even for a while
everything it's in my signature
ciauzzz
Are there still plans to start a new thread?
If anyone is interested, I updated the DSPlayer set-up guide to include installation links, configuration instructions and default support for XySubFilter in the included download files. I also added a completed playercorefactory.xml that should send live TV and Internet streams to DVDPlayer.
The link is in my signature.
I think this release warrants a new thread...
Everything appears to be working well on my test computer.
I must say thanks again to aracnoz and madshi. You have recreated my dream set-up of madVR, XySubFilter and ReClock in Kodi. I never thought it would happen.
2015-04-02, 07:08
(This post was last modified: 2015-04-02, 07:09 by oldpoem.)
Not sure, it plays fine with all those window, fullscreen mode in my GTX760 system. Can't produce the artifact like in picture you captured. Maybe try reset madvr settings to default by apply default reg. And start from scratch , it would be hard to fix if it can't reproduce on other similar system
that was a madvr issue. update madvr to 87.17!
I know I've already said it...but thanks so much for making MadVR integration happen. The image fidelity @ 4k i(1080p upscaled) is astounding!
Thanks again.
K
Sapphire RX 5700 XT (19.9.2) Ryzen 7 3700x, PRIME X570-Pro, Win 10 x64 (1903), Silverstone LC13B-E, Onkyo TX-RZ800, LG OLED55BX6LB, Mission M35i speakers, Kodi Dsplayer 17.6 X64
