2013-02-24, 04:00
Hello everybody,
today I installed a GPU (ATI HD3470) in my XBMC Machine, before that it used to use Intel Onboard graphics. Well, with the new GPU XBMC Would start properly so I downloaded the XBMCbuntu version for AMD. I wanted to install if from my USB Stick. But it always crashed. When I pressed "Try XBMCbuntu" you could see the XBMC Interface loading 3 Times and then the login screen displayed.
I tried to install it after passing the login screen, but around half way through the Installation it aborted :-(.
I hope you guys have a handy hint for me. I don't want to miss my xbmcbuntu.
BTW: after all that failed I tried openelec. That worked without problems, but I dont like openelec alot because I need full access via ssh
Thanks a lot!
Thanks a lot!
