The wiki says that my XBMC clients that you want to sync have to use the same exact version of XBMC. I have an OUYA and it requires a libstagefright build to work well. I run v12.2 on my main HTPC. Is there anyway I can get these devices to sync? Or do I just have to wait until the libstagefright stuff is merged into stable XBMC?
2013-06-17, 00:24
(This post was last modified: 2013-06-17, 00:25 by Ned Scott.)
Correct, as long as they all use the same DB version. Even some Gotham builds can be used without issue with v12.x (up to Alpha 2 for music, video is good still at Alpha 4. See table at
Monthly builds (wiki)).
Download any mysql client. HEIDISQL if on Windows or something.
Thanks. Just tried and turns out I can't connect to MySQL at all from any of the other machines.
I've turned off Windows Firewall altogether now but still can't connect. What else could be blocking off the connection?
Are you sure all devices are on the same IP subnet?
Yes, they are all on same subnet.
Main MySQL server is on 192.168.0.3.
I have a MacBook on 192.168.0.13
A Vista laptop on 192.168.0.9
My iPad is on 192.168.0.19
My iPhone is on 192.168.0.17
All have the same problem of being unable to connect to the database and hence hangs on the XBMC logo.
Hi
Do the 2 setups of xbmc have to be the exact same version? My main box is 12.2 and my gbox is running 12.0.
Matt
Main - Panasonic DX-700 UHD TV - Yamaha RXV383 - MINIX NEO U9-H running corelec 8.9.2 - Harmony Touch remote
BedRoom - Samsung UE39F5000 - Gbox 4K running coreelec 8.9.2 - Harmony One remote
Server - OMV based 10TB Media Server
(2013-06-23, 10:04)matt77303 Wrote: Hi
Matt
That will work.
