It was my experience that national blackouts weren't super enforced. I'm an skc fan living in Iowa, so I can't comment on local blackouts. But as for national blackouts....... I signed up for cable specifically to watch the MLS Cup final, but while watching that, there was a little lull in the match and I switched over to my XBMC machine, fired up the Live add-on, and there was the game! I experienced that on a couple different occasions throughout the season, with games on the 2 or 3 national networks (which shall remain unnamed) that carried matches this season.
New to XMBC. Before I purchase a G-Box Midnight MX2 from gboxcanada.com, MLS live add on will work on this machine?
Hi, I use it on the pi and it works fine -- you do need a Gotham build though I think... certainly at least Frodo (v12). Anyway, I don't imagine you'll have much trouble on the gbox if it works with stock xbmc.
You do need to pay for the service though -- I checked out the site you mentioned and despite their claims of never paying another bill again, you will need to shell out for MLS live -- well worth it though, IMO.
ngoal
Junior Member
Love this add on but it doesn't seem to be working anymore. It worked fine last week but this week none of the streams will load on frodo or Gotham.
ksosez
Senior Member
2014-04-20, 02:43
(This post was last modified: 2014-04-20, 03:40 by ksosez.)
They are pushing a fix tonight.
If you want to fix it manually, edit the file mlslive.py and look for the line in getGameLiveStream:
return stream_url.split('?')[0]
and replace it with:
return stream_url
yeah, sorry everyone.
I've fixed it and requested the pull into the main repo -- should be fixed very soon!
Update came through, issue resolved. Thanks!!
Hello everyone,
Looks like the service isn't marking games as live, so the plugin wont play them. I'm aware and will have a fix in soon.
OK, about the one hour offset -- for reasons unknown to me, the MLS live service started listing their times in GMT+1 (historically its been gmt+0). Maybe it changed with daylight savings or something...
Anyway, I have a fix but I've just requested a pull for the playback issue, so it'll show up in 1.0.10
The listing of games from MLS this week includes a match involving Ivory Coast using the French name for the country. This name has a unicode character in it which is causing the problem when passed to urlencode. The string from the listing is:
u"C\xf4te d'Ivoire at Bosnia and Herzegovina (05/30 21:30)"
Unfortunately I don't have time tonight to do a pull request, but a quick temporary fix is to open the file mlslive.py in the addon's folder (in linux, ~/.xbmc/addons/plugins/plugin.video.mlslive/) and change the last line in getGameString from:
return game_str
to
return game_str.encode('utf-8').strip()
That is line 298 in the version I'm using.
