(2015-05-30, 21:51)Milhouse Wrote: (2015-05-30, 21:43)aderlopas Wrote: Any ideas?
Not really.
Try enabling JSON-RPC in Kodi Debugging > Component Logging. Upload both your kodi.log and the log from texturecache.py (add "@logfile=c:\tc.log").
It could be a problem with ipv6, you can force ipv4 with "@rpc.ipversion=4".
Outside chance of it being a problem with Python 3.4, which I've never tested.
Many thanks for the reply. I am not sure how to attach the logs. Please let me know...
Until then, below an extract:
1. Kodi.log
23:08:24 T:18446744072008294528 DEBUG: JSONRPC: Incoming request: {"params": {"setting": "network.usehttpproxy"}, "jsonrpc": "2.0", "method": "Settings.GetSettingValue", "id": 1}
23:08:24 T:18446744072008294528 DEBUG: JSONRPC: Incoming request: {"params": {"setting": "network.httpproxytype"}, "jsonrpc": "2.0", "method": "Settings.GetSettingValue", "id": 1}
2. texturecache.log:
2015-05-30 23:11:16.214435:MainThread: Command line args: ['texturecache.py', 'c']
2015-05-30 23:11:16.214435:MainThread: Current version #: v1.9.4
2015-05-30 23:11:16.214435:MainThread: Current platform : win32
2015-05-30 23:11:16.214435:MainThread: Python version #: v3.4.3.0 (final)
2015-05-30 23:11:16.214435:MainThread: libPing.JSON WEB REQUEST: [{"id": "libPing", "method": "JSONRPC.Ping", "jsonrpc": "2.0"}]
2015-05-30 23:11:16.292587:MainThread: libPing.RECEIVED DATA: {
"id": "libPing",
"jsonrpc": "2.0",
"result": "pong"
ERROR:root:** Terminating due to unexpected exception **
File "texturecache.py", line 7754, in <module>
main(sys.argv[1:])
File "texturecache.py", line 7463, in main
if not checkConfig(argv[0]): sys.exit(2)
File "texturecache.py", line 7063, in checkConfig
data = jcomms.sendJSON(REQUEST, "libVersion", checkResult=False)
File "texturecache.py", line 1873, in sendJSON
s = self.getSocket()
File "texturecache.py", line 1801, in getSocket
raise
RuntimeError: No active exception to reraise
