Great addon - but I'm confused about the filter options. The preset filters are watched/unwatched/all but there is no way to manually set the watched status. In the description in post#1 it says the filters are wanted/snatched etc. which would be more useful anyways but those are not available. I know one can always type a custom filter into the text filter box, but that's not as convenient.
Is there a chance we can have this changed?
I can't seem to get this to work anymore. constantly gives script error.
I'm running the addon from the skin with
RunPlugin(plugin://plugin.video.couchpotato_manager/movies/add?title=$INFO[ListItem.Label])
it works perfectly.. I was just wondering if it could be possible to show a notification on success.
(don't really care about startup, since I launch a notification[] on click..)
Did I Help? Add to my reputation⬇
2015-06-07, 02:49
(This post was last modified: 2015-06-07, 02:51 by wacko37.)
This add on is brilliant..... watch your trailer then if you like it add it to your CP WANTED list.
Absolute brilliant. Great work on this add on!
I have only 1 problem and I'm sure it's an easy fix....
An option for "Add Category" this is very important part to CP to ensure you download the correct movie to your specs.
For now I'm having to edit each movie in CP to my desired Catergory.
Any intention of adding such an option
*bump* Anyone know what could be causing this?
very new to this site. Have purchased tronsmart draco AW80 which comes with kodi and couch potato is an add on. I have added it and it says it is enabled but when I try to launch it I get a message reading wrong network settings or cp is not running, then when I click yes I get a screen that asks for user name, password, use HTTPS Host name says local host Port says 5050 then set default profile then bottom line is ok, cancel or default. Have tried uninstalling and re installing but still come up with the same problem. Hope someone can help with this issue.
Having issues getting CP to run in Kodi:
00:09:25 565.105530 T:1813206080 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.KeyError'>
Error Contents: ('info',)
File "/storage/.kodi/addons/XBMC-CouchPotato-Manager-master/addon.py", line 448, in <module>
plugin.run()
File "/storage/.kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 332, in run
items = self._dispatch(self.request.path)
File "/storage/.kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 306, in _dispatch
listitems = view_func(**items)
File "/storage/.kodi/addons/XBMC-CouchPotato-Manager-master/addon.py", line 287, in show_releases
info = release['info']
KeyError: ('info',)
00:09:25 565.245789 T:1968472064 ERROR: GetDirectory - Error getting plugin://plugin.video.couchpotato_manager/movies/0db7bc5250604cb3aa9a721d465e1ebd/rel$
00:09:25 565.250366 T:1968472064 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.couchpotato_manager/movies/0db7bc5250604cb3aa9a721d465e1ebd/re$
00:09:25 565.367859 T:1813206080 NOTICE: Thread BackgroundLoader start, auto delete: false
Anyone else having this problem? Know a solution?
