2013-05-24, 18:41
(This post was last modified: 2013-08-12, 01:59 by artrafael.)
Hi Margro,
would be cool if you could provide this soon.
Many Thanks
JuRo
margro
Posting Freak
2013-06-01, 21:21
(This post was last modified: 2013-06-01, 21:24 by margro.)
Did you already try the plugin for 1.3? It will probably just work unless the TVServer API changed.
I've no plans to install this pre-release just to rebuild the tvserverxbmc plugin. I want to keep my 1.2 and 1.3 installations up and running for development purposes.
Hi there,
Can anyone confirm whether the latest TV Server Plugin does indeed work with 1.4?
I had to wipe my Raspberry Pi recently (having not used is since I upgraded Mediaportal to 1.4) and I cannot connect to Mediaportal Server.
I cannot now tell whether the plugin is the problem or not.
Well, i just downloaded the latest Media portal today (Looks like it's full 1.4 as of the 18th) as i'm switching computers around and it looks like the server plugin does not work with it.
I get a pop-up "dependency error" saying: "requires MediaPortal version 1.3.0 to 1.3.999."
when I hit the button to view the addition detials, here is what I see.
"Name" | "type" | "Min" | "Max"
TvServer | Installer | 1.2.200.0 | 1.3.999.0
MediaPortal | MediaPortal | 1.1.6.27644 | 1.1.6.27644
I'm running windows XP SP3 if you needed the OS i'm running.
If you need any additional detail, just ask and I'll try to give them to the best of my ability.
Many thanks for this.
Just out of interest, how difficult was it to re-compile the code as mentioned above?
Do you need major coding experience to do this?
So, since I am not a MP User, is it worth to update TVServer to 1.4?
Is the updated plugin working fine?
Dakkar
2013-06-23, 18:53
(This post was last modified: 2013-06-23, 18:57 by Mercury_22.)
After updating the plugin I can't order the channels by name in XBMC
No matter how I'm ordering them in the server the new plugin doesn't respect the order from the server ( order by name in the server)
Going back to v1.3.0.121 has solve the problem. This problem has been introduced in v1.3.0.122
I had issues with the 1.4 specific plugin and the EPG. So I went back to v1.3.0.121. The 1.4 specific new version freezes and then crashes xbmc as soon as you try to goto the EPG. Was doing this with windows versions of XBMC. If some debug or something is needed I can try to get that....this 1.3 version works fine for me for now though.
Yes, on Client side both entries are green, and the port 9596 is ok in the FW.
