Movielib waits with sync to XBMC get full info about streamdetails (codec, dimension, etc.).
For typical videos like (avi, mkv, wmv, wmv) XBMC get this info immediately, but in the case of packed files (ISO, IFO) XBMC to get streamdetails the file must be played at least once.
The "Force sync ISO and IFO files" option sync movies without waiting. Unfortunately I did not know about the file stubs and not added they to this condition.
Soon a new version of the script will synchronize all at once, and keep up to date with any change in them.
In addon settings turn on debugging and paste here xbmc.log after error display using pastebin.com.
OMFG.....So I just spent my first time messing with mysql and got this up and running. Spent about 4 hours configuring and messing with any and all options and I have to say:
THANK YOU SO MUCH!
This was EXACTLY the next step I needed to take for my htpc and now everything (with the exception of editing the website template) is FINALLY complete! Thank you again sooooo much Regss!
2014-10-23, 18:57
(This post was last modified: 2014-10-23, 18:59 by _Andy_.)
Thanks Regss. The server is a VM on a ESXi with a Win7 32bit with 4GB RAM. I use apache on windows. The MySQL server is on the same machine.
Yesterday before i tried to sync i restarted all machines.
2014-10-23, 22:09
(This post was last modified: 2014-10-23, 22:33 by _Andy_.)
If i disable sync actor thumbs it's working. I have no clue why.
I reinstalled the apache server and cleaned the database but with sync actors on it's not working.
The syncing of poster for movies and tvshows is working fine.
i get through the set up and it brings up the page to go to the admin.php page, but when i click it, it redirects to the the install.php page every time. any idea whats wrong?
2014-11-11, 10:50
(This post was last modified: 2014-11-11, 11:05 by Regss.)
Check if db.php file exist in script root directory, maybe script can't create it. Try change chmod attribute for directory.
Do you get any error? Like Permission denied or else?
2014-11-18, 22:18
(This post was last modified: 2014-11-18, 22:55 by Regss.)
New version of Movielib is avaliable. To update replace all files and go to admin panel. The database will be updated. Sync settings have been moved to the settings section in the admin panel. KODI addon will be automatically updated to version 1.3.0.
All movies and tvshows will be updated. Now if XBMC will change any info about movie/tvshow like plot, title, poster, fanart etc. movielib also will do it.
changelog v.2.7.0:
- added extra thumbs
- added support for multi audio track
- added audio and subtitles language
- now movies info update when XBMC do some changes
- added actors to live search
To synchronize the extrathumbs must be named accordance with the rule:
/[movie]/extrathumbs/thumb1.jpg
/[movie]/extrathumbs/thumb2.jpg
Levi59
Senior Member
2014-11-20, 19:42
(This post was last modified: 2014-11-20, 20:50 by Levi59.)
Hello! I am currently using MySql to synchronize my databases on my Synology and I would like to have a web page for navigating my movies and my tv series, such as seems to do this addon, but without allowing modification of databases and without control of xbmc, directly on the syno which has a url.
Will there a way to get there from your addon?
