2014-11-20, 22:07
From my website you can control XBMC. Only simple control avaliable like play, stop movie or change volume, but first you must install it and sync all data from XBMC to website.
<?PHP $mysql_ml = array('host', 'port', 'login', 'password', 'database'); ?>
name":"Michael Rooker","order":7,"role":"Merle Dixon"},{"name":"Emily Kinney","order":8,"role":"Beth Greene"},{"name":"Scott Wilson","order":9,"role":"Hershel Greene"},{"name":"IronE Singleton","order":10,"role":"T-Dog"},{"name":"Lauren Cohan","order":11,"role":"Maggie Greene"},{"name":"Danai Gurira","order":12,"role":"Michonne"},{"name":"Steven Yeun","order":13,"role":"Glenn"},{"name":"Emma Bell","order":14,"role":"Amy"},{"name":"Laurie Holden","order":15,"role":"Andrea"},{"name":"Jeffrey DeMunn","order":16,"role":"Dale"},{"name":"Jon Bernthal","order":17,"role":"Shane Walsh"},{"name":"Sarah Wayne Callies","order":18,"role":"Lori Grimes"}],"genre":["Drama","Horror","Suspense"],"label":"The Walking Dead","tvshowid":39},{"cast":[{"name":"Travis Fimmel","order":0,"role":"Ragnar Lothbrok"},{"name":"Katheryn Winnick","order":1,"role":"Lagertha"},{"name":"Clive Standen","order":2,"role":"Rollo"},{"name":"Gustaf Skarsgard","order":3,"role":"Floki"},{"name":"George Blagden","order":4,"role":"Athelstan"},{"name":"Jessalyn Gilsig","order":5,"role":"Siggy"},{"name":"Gabriel Byrne","order":6,"role":"Earl Haraldson"}],"genre":["Action","Adventure","Drama","Mini-Series"],"label":"Vikings","tvshowid":41},{"cast":[],"genre":["Documentary"],"label":"Wildes Deutschland","tvshowid":42},{"cast":[{"name":"Christian Cooke ","order":0,"role":"Frederick Beauchamp "},{"name":"Julia Ormond","order":1,"role":"Joanna Beauchamp"},{"name":"Jenna Dewan-Tatum","order":2,"role":"Freya Beauchamp"},{"name":"Rachel Boston","order":3,"role":"Ingrid Beauchamp"},{"name":"Mädchen Amick","order":4,"role":"Wendy"},{"name":"Eric Winter","order":5,"role":"Dash Gardiner"},{"name":"Daniel DiTomasso","order":6,"role":"Killian Gardiner"},{"name":"Bianca Lawson","order":7,"role":"Eva"},{"name":"Enver Gjokaj ","order":8,"role":"Mike"},{"name":"Joel Gretsch","order":9,"role":"Victor"},{"name":"Shaun Smyth","order":10,"role":"Dr. Frank Foster"},{"name":"Tom Lenk","order":11,"role":"Hudson Rafferty"},{"name":"Virginia Madsen","order":12,"role":"Penelope Gardiner"}],"genre":["Drama","Fantasy","Suspense"],"label":"Witches of East End","tvshowid":57}]}}
15:57:32 T:11664 DEBUG: ------ Window Init (DialogExtendedProgressBar.xml) ------
15:57:33 T:17212 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeDecodeError'>
Error Contents: 'ascii' codec can't decode byte 0xc3 in position 8: ordinal not in range(128)
File "C:\Users\Stefan\AppData\Roaming\XBMC\addons\script.movielib\default.py", line 29, in <module>
Movielib()
File "C:\Users\Stefan\AppData\Roaming\XBMC\addons\script.movielib\default.py", line 21, in __init__
sync.start(self)
File "C:\Users\Stefan\AppData\Roaming\XBMC\addons\script.movielib\lib\sync.py", line 51, in start
check(self)
File "C:\Users\Stefan\AppData\Roaming\XBMC\addons\script.movielib\lib\sync.py", line 132, in check
if syncVideo.sync(self, v) is False:
File "C:\Users\Stefan\AppData\Roaming\XBMC\addons\script.movielib\lib\syncVideo.py", line 44, in sync
if syncPanel.sync(self) is False:
File "C:\Users\Stefan\AppData\Roaming\XBMC\addons\script.movielib\lib\syncPanel.py", line 137, in sync
debug.notify(__lang__(32104).encode('utf-8') + ' ' + str(addedCount) + ' ' + self.panelsLang[panel])
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 8: ordinal not in range(128)
15:57:33 T:17212 INFO: Python script stopped
15:57:33 T:17212 DEBUG: Thread LanguageInvoker 17212 terminating
15:57:33 T:11664 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
15:57:33 T:11664 DEBUG: ------ Window Deinit (DialogExtendedProgressBar.xml) ------
15:57:38 T:11664 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
15:57:38 T:11664 DEBUG: CWinEventsWin32::WndProc: window move event
15:57:44 T:11664 DEBUG: Previous line repeats 39 times.
15:57:44 T:11664 DEBUG: CWinEventsWin32::WndProcWindow is active
15:57:50 T:11664 DEBUG: ------ Window Deinit (Pointer.xml) ------
15:57:54 T:11664 DEBUG: SECTION:UnloadDelayed(DLL: spec
