  • 29
  • 30
  • 31(current)
  • 32
  • 33
  • 45
MovieLib - Your movie database on web
Htaccess file is necessary only if you using rewrite module.
First: What a great thing you created, Regss, thank you!
I'm very new at this stuff - webhostig, webpages and so on.
But I got it working, the database, the connection to Kodi, it lists the movies but there is one problem.
I can't see any posters. Can you help me with that?
I scrape all my movies with Ember MediaManager, so I have all information locally in the movie folder.
Structure is like this:
Team America (2004)
Ted (2012)
.....extrathumbs
.....Ted.mkv
.....Ted.nfo
The Amazing Spider-Man (2012)
But no pictures are synched with the server? I host on uberspace, if there is anyone else, who uses this hoster.
Thanks in advance!
I need kodi.log to recognize the problem. You must enable debuging in movielib addon settings. And sync at least one movie. If you have synced all movies you must login to admin panel on website and delete one movie in movie list section then go to kodi and run sync.
So I enabled logging and updated my collection - but where do I find the log now?
I use Kodi on my Fire TV .. so I'm not able to search for the log.
Edit: Okay, found it, post it soon.
A big thanks. This is just what I was looking for, and it was so easy to install and get running (although the first sync took 5 hours to complete).
I would like to customise the pages if you don't mind. Can you tell me what IDE/Development and plugins tools you use.
Yes, if you want good quality of posters and fanarts first sync may take a while.
For PHP, HTML, CSS i use only Notepad++. You can edit TPL and CSS files to customize pages. It is very easy but the minimum knowledge needed.
Thanks very much. I have Notepad++ installed already and also the Eclipse PHP IDE.
I did expect a lengthy initial load as I have 1500 movies and 8600 episodes. Are you planning to extend this to include Music as well?
No I don't. It would take a lot of time on that currently do not have.
Hello all
I have two problems and I cant solve them.
movielib is installed on my local webserver. Its running centos7. Selinux ist set to permissive. In selinux-management httpd_enable_cgi, httpd_unified, http_builtin_scripting are enabled. In selinux-alertbrowser are not messages found.
First I have set cache and cache/actors to chmod 777 but the folder actors is empty.
In the movielib-database table actor are filled with nearly 45000 lines.
In the kodi-db myvideos93 table actors are the name and art_urls filled but the links are not addressed to my local actor-folders they addressed to http://ia.media-imdb.com.
In userdata/Thumbnails are no actor-pics.
Where is the problem? How can I solve this?
The second problem is when I click on a movie title movielib set a filter to the title. Going back by clicking on the red arrow (delete results). All fine.
But when I select something from the left panel e.g. genre e.g. thriller I get the movies with genres thriller but I cant delete the filter with the red arrow. Tested with chrome, FF and ie.
Can I solve this or is it a bug?
Do the Actors Url links in kodi database lead to existed image?
(2015-08-15, 14:10)Regss Wrote: Do the Actors Url links in kodi database lead to existed image?
Yes it do.
e.g.
<thumb>http://ia.media-imdb.com/images/M/MV5BMjE1MjYwNTE2M15BMl5BanBnXkFtZTYwNTI0NjI1._V1._SY275_SX400_.jpg</thumb>
Sorry, I have forgotten to tell you I use Kodi 15.0.
and now I think I have found the actors. Its crazy but they are saved in the kodi.log
I have installed your repo, Kodi restart, activate add-on, restart Kodi, set settings, restart Kodi then the kodi.log looks like this.
Look at here: Link deleted
Do the posters and fanarts sync correctly?
Please turn on debuging in movielib addon settings. Run sync and after that paste kodi.log using pastebin.com.
(2015-08-15, 17:52)Regss Wrote: Do the posters and fanarts sync correctly?
Yes.
(2015-08-15, 17:52)Regss Wrote: Please turn on debuging in movielib addon settings. Run sync and after that paste kodi.log using pastebin.com.
Done, but after synch 50 movies I decided to shutdown kodi because kodi.log get 55 MB.
Sorry I cant upload to pastebin.com because there a so much rows that my broswer crashed pastebin.com.
The only way I can share the log is like here: Link deleted
To test actors sync you must delete entire database becouse now actors are synced and movielib not try to update it.
It strange that poster and fanart are synced correctly but actors not. Make sure that folder cache/actors have acces to write to it.
  • 29
  • 30
  • 31(current)
  • 32
  • 33
  • 45
  • 8 Vote(s) - 4.63 Average
MovieLib - Your movie database on web4.638
