mzup
Senior Member
Lunatix is there an issue with latest master push? Just installed it and when I go to launch it nothing happens. I put the one from 10/27 back on and it works fine. I completely removed ptvl and installed latest again and still nothing happens.
2013-10-30, 00:56
(This post was last modified: 2013-10-30, 00:58 by scilz.)
i have no idea how ppl are getting these times wrong but it's on your end and not ptvl.
and i think it will show a short listing for bct's in between the shows/movies but luna would have to confirm that
ARYEZ
Senior Member
To piggy back on what scilz and luna are saying my EPG is a grid as well...what I think the poster is saying is that his EPG shows aren't lining up with the times across the top. FWIW the reason for this is because the times across the top are 3 in 30 minute intervals. For instance right now my visible listings would be 7, 7:30, and 8pm. Because library content is conmercial free you are dealing with shows that's are either 21 or 42 minutes so they don't not line up cleanly with the 30 minute intervals the EPG is split into. This isn't a problem that needs fixing though because live tv needs the thirty minute interval display otherwise your live programming schedule would be screwed up.
i dont think you could get this to work unless all your bct's where 2 minutes long. then you could have 22 minute show followed by 4 bct's and that would be 30 minutes. but you would still see 5 items a 22 min show then a 2 min bct then another 2 min bct ect. but your next show would then start on the hour.
i am having one peculiar issue, my left and right arrow keys act differently on live tv. i normally set it to 30 sec forward 7 back, ordinary network ptv channels do fine, live tv acts real funky and buggy, forward does fine, backward needs rapid pressing for any progress and stops working more every time you hit left.
after resetting the timeline by the bar you can do it a lil more, but it still takes two left presses to go 7 seconds back
