2014-01-11, 10:28
If anyone is wondering why it doesn´t work at the moment, dropbox is down.
cd.upgrade
mkdir -p xbmc-13-20140110-nc3-2
tar -xzf 0B_pnxTjg-ojhNzBjc1diOWI0b2c.tar -C xbmc-13-20140110-nc3-2
cd xbmc-13-20140110-nc3-2/xbmc-bcm/xbmc-bin/lib/xbmc/system
cp /usr/local/lib/libdvdcss.so.2.1.0 .
ln -sf libdvdcss.so.2.1.0 libdvdcss.so.2
ln -sf libdvdcss.so.2 libdvdcss.so
(2014-01-11, 15:48)fernandovg Wrote: You can hear the crack noise then the subtitle blocks
Its happening for every single mkv file
(2014-01-11, 23:05)miappa Wrote: Should have checked jenkins first, this build failed.
I see that memphiz is working on it, if he fixes compiling for Pi I will try again.
I know where it failed but have no idea how to fix, if anyone wants to look into it let me know.
<?xml version="1.0" encoding="UTF-8"?>
<advancedsettings>
<cputempcommand>/opt/vc/bin/vcgencmd measure_temp | sed -e 's/temp=\([0-9]*\).*/\1 C/'</cputempcommand>
<gputempcommand>/opt/vc/bin/vcgencmd measure_temp | sed -e 's/temp=\([0-9]*\).*/\1 C/'</gputempcommand>
<network>
<cachemembuffersize>5242880</cachemembuffersize>
</network>
<imageres>540</imageres>
<fanartres>720</fanartres>
<video>
<defaultplayer>omxplayer</defaultplayer>
<defaultdvdplayer>omxplayer</defaultdvdplayer>
</video>
<audio>
<defaultplayer>paplayer</defaultplayer>
</audio>
</advancedsettings>
