Updated Gotham build,
XBMC master from Mar 06 +
newclock3 commits + additional commits.
Some info:
• NC3: Support for virtual suspend/sleep mode (HDMI power saving) *
• NC3: Skip the resize when not needed when decoding jpegs (memory and speed improvements)
• NC3: Use media for determing audio delay and cache time
• NC3: Skip picture attachments in music files they cause audio to hang (in tags?)
• NC3: Make actual power off disabled unless overridden (in advancedsettings.xml?)
• NC3: Test: Improved support for airplay and IOS7 clients
• Additional/SQLite:
Updated SQLite version
Use mmap to accelerate SQLite file accesses
• Additional:
Fix memory leakage in python bindings
• Additional:
DVD various fixes related to libdvdnav issues and skip to menu (updated)
Firmware from 28th of Feb recommended.
Firmware update, recommendations and additional testing (DVDPlayer etc.),
see post #1
To install XBMC build, SSH to Pi:
cd .upgrade
wget -O xbmc-13-20140306-nc3.tar.gz http://goo.gl/69gZd4 --no-check-certificate
mkdir -p xbmc-13-20140306-nc3
pv xbmc-13-20140306-nc3.tar.gz | tar xzf - -C xbmc-13-20140306-nc3
cd xbmc-13-20140306-nc3/xbmc-bcm/xbmc-bin/lib/xbmc/system
cp /usr/local/lib/libdvdcss.so.2.1.0 .
ln -sf libdvdcss.so.2.1.0 libdvdcss.so.2
ln -sf libdvdcss.so.2 libdvdcss.so
Activate new build in "Raspbmc Settings/Nightly…/Switch…”, choose new build + restart XBMC.
* Support for virtual suspend/sleep mode
Enable this feature in ’Settings - System - Power Saving’ -> set ’Shutdown function’ to ’ Suspend’.
This will not put the Pi into a ”real” sleep mode, only disable HDMI (until any action from keyboard or remote).
