  • 72
  • 73
  • 74(current)
  • 75
  • 76
  • 119
RaspBMC Kodi/XBMC test builds
(2014-04-06, 13:29)miappa Wrote: Tried it: rebooted, added a movie, highlighted and crash (first froze for 10 seconds then reboot).
10 seconds sounds like the watchdog timeout (which is 10 seconds) after a hard system freeze... Wink
Kodi 18.3 - Mid 2007 Mac Mini, 4GB, 2TB HD, Windows 7 SP1
Kodi 18.3 - Vero4k, Raspberry Pi 2. OSMC.
Okay, there were some camera changes that affect jpeg encode.
Any better with those reverted:
https://dl.dropboxusercontent.com/u/3669..._nocam.elf
That seems to fix it!
Well, at least when trying to reproduce it one time, but it has ben easy to reproduce it though so looks promising.
Okay, I've had a different report that start_nopll fixed a similar problem, so I want to be sure:
This just reverts camera and not PLL. Is it okay?
https://dl.dropboxusercontent.com/u/3669...nocam2.elf
The last one also seems to work.
[email protected]:~$ vcgencmd version
Apr  6 2014 12:40:02
Copyright (c) 2012 Broadcom
version 60187bab9df18481fb70f7df0776fa2f1bb7f134 (tainted) (release)
Well, I didn´t think of trying other stuff, I just tried to reproduce it.
But playing HD videos does not seem to work very good. Very slow, almost impossible to seek and a couple of XBMC crashes.
I do have a mix now though (your latest start + 30th March fixup), perhaps not proper.
Should I try anything else or is this expected?
Edit: Nvm, it´s an out of memory crash and certainly caused by the 128/128 split. Will revert until firmware is updated.
(2014-04-06, 14:12)miappa Wrote: Well, I didn´t think of trying other stuff, I just tried to reproduce it.
No, mixing xbmc and firmware shouldn't be a problem (within the last few weeks).
So, can you confirm the slow video only occurs with these test builds/latest and was okay with:
https://github.com/Hexxeh/rpi-firmware/c...49286e2210
I think it´s an out of memory problem, you mentioned it had a fixed 128/128 split so it´s probably that.
It is reporting only ≈120 and I am probably on to heavy skin etc. for that.
Curious though, why 128/128?
And yes, it works perfectly fine on older firmware (with my custom split).
(2014-04-06, 14:24)miappa Wrote: Curious though, why 128/128?
The first bug report I had was from a 256M Pi, so I made that split.
I've been able to reproduce the memory corruption. If I can fix it without reverting the camera change I'll make the next test build 256/256.
Okay this has no reverts, but I've attempter to fix the camera commit:
https://dl.dropboxusercontent.com/u/3669...nocam3.elf
It is also a 256/256 memory split. Is this okay?
Yep, seems to work fine. Tried it twice (added a single new movie and highlighted to fetch the artwork) to make somewhat sure.
And playing HD content works well too.
Apr  6 2014 14:00:53
version 7072433f2b6e5e7b717073969db662e991638978 (tainted) (release)
(2014-04-06, 15:12)miappa Wrote: Yep, seems to work fine. Tried it twice (added a single new movie and highlighted to fetch the artwork) to make somewhat sure.
Official firmware is updated with this fix.
Great, thanks a lot.
Where can I find this update or is it implemented in 0404-version ?
You can manually download firmware file (start_x.elf) and switch it with the files on your CD card.
But I´ll post a new build soon with this fix too.
  • 72
  • 73
  • 74(current)
  • 75
  • 76
  • 119
RaspBMC Kodi/XBMC test builds15
