  • 6(current)
  • 7
[RELEASE] VEVO TV - Watch music videos 24/7
#76
(2014-06-03, 00:46)AddonScriptorDE Wrote: v1.1.2:
- Added M3U8 quality selection
- Removed rtmp streaming type
v1.1.3:
- Added M3U8 CDN selection
(2014-03-29, 11:14)Rouzax Wrote: One other thing I've noticed. When I select InfoView in the settings instead of notification it just opens my menu bar as if I press on "Enter" on my keyboard. It should be "i" for info.
Yes, from a previous post: "I only found the id for the info view with player controls ('enter'). If anybody knows the id without the controls ('i'), please let me know"...
(2014-04-03, 20:44)Tappy Wrote: How do I get this addon?
Install my testing-repo!
(2014-04-09, 23:35)pjam3110 Wrote: This addon is really nice. But i miss the login and the playlist which i added on my computer. Is it possible to do that.
You can add your (and any other) playlists by saving the playlist ID in the addons userdata folder. Just have a look at the examples.
(2014-04-29, 17:36)joe1480 Wrote: Is this add-on suppose to work with windows gotham?
It says incompatible in my list. If it isn't gotham supported, will it be?
It should be compatible. I'll have a look at it...
(2014-05-10, 12:32)Rouzax Wrote: It appears that that are again some video's that are not shown and skipped.
For example http://www.vevo.com/watch/sia/chandelier...RV81400135 does not load.
Should be fixed in the latest version.
(2014-05-13, 20:34)ScottyRads Wrote: One "bug". I launch from the home menu. When I Play VEVO TV (US:Hits) and hit stop (x, esc, backspace) it brings me back to home menu. If I play anything custom it takes me back to the video addons folder once i stop. Anyway to have this jump back to home like the first selection?
I don't really know if I can affect this and if it's related to the addon.
The info window should be listed in the following link: http://wiki.xbmc.org/?title=Window_IDs
Any one having issues with playback? Im having issues with videos stuttering/stop playing? Ive set video quality to low. on windows 8 Gotham.
Hey adse,
Still loving this add-on Smile
This still being updated?
I don't get the song names anymore just loads of numbers
This addon has region issues now and I'm in the USA...
Error: VEVO is not available in your country
same problem here.
i live in the netherlands
same issue here in Canada.... not available in your country Sad
Yeah, used to work for me in Canada, but noticed a week or so ago it stopped working. Giving the "not available in your country" message.
That's unfortunate. Any alternative to just throwing some music videos on?
(2015-09-08, 18:30)kossatzd Wrote: Yeah, used to work for me in Canada, but noticed a week or so ago it stopped working. Giving the "not available in your country" message.
Look in Kodi repo for Vevo (in Videos) by t1m. It has Vevo Tv included.
not available in your country located in USA
(2015-09-09, 04:45)thekid Wrote: not available in your country located in USA
you can test my fixed Version 1.1.4
Changelog Version 1.1.4
1.1.4 by skatulskijean
- fix VEVO TV (US:Hits)
- fix VEVO TV (US:Flow)
- fix VEVO TV (US:Nashville)
- fix VEVO TV (Germany)
- fix Custom (all Videos)
- fix Custom (live Videos)
Download we many other fixed Addons from ASDE from the Lost and Found Repo:
https://github.com/kodinerds/repo/raw/ma...-found.zip
regards Jan
regards Jan
Confirming. I had the same country issue (in the US) and I installed this repo, and the addon instantly auto-updated and my Vevo TV is again working!
Thank you very much for fixing it.
regards Jan
Super - confirming Vevo plugin works without the error in Canada in ver. 1.1.4
Thanks a lot for your contribution
I've been getting Vevo TV error since yesterday when trying to play from Custom menu's, the channels work fine like US Hits, Flow etc on version 1.1.4
Anyone else having the same issue?
DoubleZero
  • 6(current)
  • 7
[RELEASE] VEVO TV - Watch music videos 24/70
