Error when launching Add-On. Please help
19:48:48 T:10576 NOTICE: special://profile/ is mapped to: special://masterprofile/
19:48:48 T:10576 NOTICE: -----------------------------------------------------------------------
19:48:48 T:10576 NOTICE: Starting XBMC (13.2 Git:20140817-0f3db05). Platform: x86 Win32 32-bit
19:48:48 T:10576 NOTICE: Using Release XBMC x32 build, compiled Aug 17 2014 by MSVC 160040219 for x86 Win32 32-bit version 0x06000000
19:48:48 T:10576 NOTICE: Running on Windows 8.1 64-bit, build 9600
19:48:48 T:10576 NOTICE: Host CPU: Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz, 4 cores available
19:48:48 T:10576 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
19:48:48 T:10576 NOTICE: Running with restricted rights
19:48:48 T:10576 NOTICE: Aero is enabled
19:48:48 T:10576 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
19:48:48 T:10576 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
19:48:48 T:10576 NOTICE: special://masterprofile/ is mapped to: C:\Users\Steven\AppData\Roaming\XBMC\userdata
19:48:48 T:10576 NOTICE: special://home/ is mapped to: C:\Users\Steven\AppData\Roaming\XBMC\
19:48:48 T:10576 NOTICE: special://temp/ is mapped to: C:\Users\Steven\AppData\Roaming\XBMC\cache
19:48:48 T:10576 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
19:48:48 T:10576 NOTICE: Local hostname: WINDOWS-OCN975P
19:48:48 T:10576 NOTICE: Log File is located: C:\Users\Steven\AppData\Roaming\XBMC\xbmc.log
19:48:48 T:10576 NOTICE: load settings...
19:48:48 T:10576 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
19:48:48 T:10576 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
19:48:48 T:10576 NOTICE: Default DVD Player: dvdplayer
19:48:48 T:10576 NOTICE: Default Video Player: dvdplayer
19:48:48 T:10576 NOTICE: Default Audio Player: paplayer
19:48:48 T:10576 NOTICE: Disabled debug logging due to GUI setting. Level 0.
19:48:48 T:10576 NOTICE: Log level changed to 0
19:48:48 T:10576 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
19:48:48 T:10576 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
19:48:48 T:10576 NOTICE: Loaded playercorefactory configuration
19:48:48 T:10576 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
19:48:48 T:10576 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
19:48:48 T:4468 NOTICE: Thread ActiveAE start, auto delete: false
19:48:48 T:8452 NOTICE: Thread AESink start, auto delete: false
19:48:48 T:4468 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: data format "AE_FMT_AAC" on device "TX-NR828-4 (NVIDIA High Definition Audio)" seems to be not supported.
19:48:48 T:4468 NOTICE: CAESinkWASAPI::EnumerateDevicesEx: sample rate 192khz on device "Speakers (DTS PlayFi Audio Renderer)" seems to be not supported.
19:48:48 T:4468 NOTICE: Found 2 Lists of Devices
19:48:48 T:4468 NOTICE: Enumerated DIRECTSOUND devices:
19:48:48 T:4468 NOTICE: Device 1
19:48:48 T:4468 NOTICE: m_deviceName : {45AF5BAC-F397-4C35-96C8-8640235E4F05}
19:48:48 T:4468 NOTICE: m_displayName : HDMI - TX-NR828-4 (NVIDIA High Definition Audio)
19:48:48 T:4468 NOTICE: m_displayNameExtra: DIRECTSOUND: TX-NR828-4 (NVIDIA High Definition Audio)
19:48:48 T:4468 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
19:48:48 T:4468 NOTICE: m_channels : FL,FR,FC,BL,BR,SL,SR,LFE
19:48:48 T:4468 NOTICE: m_sampleRates : 48000
19:48:48 T:4468 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3,AE_FMT_DTS
19:48:48 T:4468 NOTICE: Device 2
19:48:48 T:4468 NOTICE: m_deviceName : default
19:48:48 T:4468 NOTICE: m_displayName : default
19:48:48 T:4468 NOTICE: Device 3
19:48:48 T:4468 NOTICE: m_deviceName : {D14703EB-BADF-4650-9C47-3DCA6709BC86}
19:48:48 T:4468 NOTICE: m_displayName : Speakers - Speakers (DTS PlayFi Audio Renderer)
19:48:48 T:4468 NOTICE: m_displayNameExtra: DIRECTSOUND: Speakers (DTS PlayFi Audio Renderer)
19:48:48 T:4468 NOTICE: m_deviceType : AE_DEVTYPE_PCM
19:48:48 T:4468 NOTICE: m_sampleRates : 44100
19:48:48 T:4468 NOTICE: Enumerated WASAPI devices:
19:48:48 T:4468 NOTICE: m_displayNameExtra: WASAPI: TX-NR828-4 (NVIDIA High Definition Audio)
19:48:48 T:4468 NOTICE: m_channels : FL,FR,FC,LFE,BL,BR,SL,SR
19:48:48 T:4468 NOTICE: m_sampleRates : 192000,96000,48000,44100
19:48:48 T:4468 NOTICE: m_dataFormats : AE_FMT_DTSHD,AE_FMT_TRUEHD,AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
19:48:48 T:4468 NOTICE: m_displayNameExtra: WASAPI: Speakers (DTS PlayFi Audio Renderer)
19:48:48 T:4468 NOTICE: m_sampleRates : 192000,44100
19:48:48 T:10576 NOTICE: Running database version Addons16
19:48:48 T:10576 NOTICE: ADDONS: Using repository repository.addonscriptorde-beta
19:48:48 T:10576 NOTICE: ADDONS: Using repository repository.xbmc.org
19:48:48 T:10576 NOTICE: ADDONS: Using repository repository.pvr-win32.xbmc.org
19:48:48 T:10576 NOTICE: ADDONS: Using repository repository.superrepo.org.gotham.all
19:48:48 T:9156 NOTICE: Thread RemoteControl start, auto delete: false
19:48:48 T:4908 NOTICE: Thread PeripBusCEC start, auto delete: false
19:48:48 T:1464 NOTICE: Thread PeripBusUSB start, auto delete: false
19:48:48 T:10576 NOTICE: Found screen: Dummy Monitor on NVIDIA GeForce GTX 660, adapter 0.
19:48:48 T:10576 NOTICE: Primary mode: 1920x1080@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Previous line repeats 2 times.
19:48:48 T:10576 NOTICE: Additional mode: 640x480@ 72.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 640x480@ 75.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 720x480@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 720x480@ 59.94 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 720x576@ 50.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 800x600@ 72.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 800x600@ 75.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1024x768@ 70.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1024x768@ 75.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1152x864@ 75.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1176x664@ 50.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1176x664@ 59.94 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1176x664@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1280x720@ 50.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1280x720@ 59.94 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1280x800@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1280x960@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1280x960@ 75.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1280x1024@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1280x1024@ 75.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1680x1050@ 59.94 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1680x1050@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1768x992@ 25.00i - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1768x992@ 29.97i - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1768x992@ 30.00i - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1920x1080@ 59.94 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1920x1080@ 25.00i - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1920x1080@ 29.97i - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1920x1080@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1920x1080@ 50.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1920x1080@ 30.00i - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1920x1080@ 23.98 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1920x1080@ 24.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1920x1080@ 25.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1920x1080@ 29.97 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1920x1080@ 30.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1440x900@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Additional mode: 1600x900@ 60.00 - Full Screen
19:48:48 T:10576 NOTICE: Checking resolution 16
19:48:49 T:10576 NOTICE: No Joystick name specified, loading default map
19:48:49 T:10576 NOTICE: Previous line repeats 35 times.
19:48:49 T:10576 NOTICE: Running database version Addons16
19:48:49 T:10576 NOTICE: Running database version ViewModes6
19:48:49 T:10576 NOTICE: Running database version Textures13
19:48:49 T:10576 NOTICE: Running database version MyMusic46
19:48:49 T:10576 NOTICE: Running database version MyVideos78
19:48:49 T:10576 NOTICE: Running database version TV22
19:48:49 T:10576 NOTICE: Running database version Epg7
19:48:49 T:10576 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
19:48:49 T:10576 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
19:48:49 T:10376 NOTICE: Thread LanguageInvoker start, auto delete: false
19:48:49 T:10576 NOTICE: Previous line repeats 1 times.
19:48:49 T:10576 NOTICE: initialize done
19:48:49 T:10016 NOTICE: Thread LanguageInvoker start, auto delete: false
19:48:49 T:10576 NOTICE: Running the application...
19:48:49 T:10376 NOTICE: -->Python Interpreter Initialized<--
19:48:49 T:2148 NOTICE: Thread JobWorker start, auto delete: true
19:48:49 T:10576 NOTICE: Webserver: Starting...
19:48:49 T:10276 NOTICE: -->Python Interpreter Initialized<--
19:48:49 T:10016 NOTICE: -->Python Interpreter Initialized<--
19:48:49 T:10576 NOTICE: WebServer: Started the webserver
19:48:49 T:10576 NOTICE: ES: Starting event server
19:48:49 T:11196 NOTICE: Thread EventServer start, auto delete: false
19:48:49 T:11196 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
19:48:49 T:11196 NOTICE: UDP: Listening on port 9777
19:48:49 T:2000 NOTICE: Thread TCPServer start, auto delete: false
19:48:49 T:10580 NOTICE: -->Python Interpreter Initialized<--
19:48:49 T:8620 NOTICE: Thread RSSReader start, auto delete: false
19:48:49 T:10016 NOTICE: 1Channel: Loading sqlite3 as DB engine
19:48:49 T:10580 NOTICE: StorageServer Module loaded RUN
19:48:49 T:10580 NOTICE: StorageClient-2.5.4 Starting server
19:48:49 T:10016 NOTICE: 1Channel: Building PrimeWire Database
19:48:49 T:10016 NOTICE: PrimeWire: Service: Resetting...
19:48:49 T:10016 NOTICE: PrimeWire: Service starting...
19:48:50 T:9436 NOTICE: Thread JobWorker start, auto delete: true
19:48:54 T:10080 NOTICE: Previous line repeats 1 times.
19:48:54 T:10080 NOTICE: Thread BackgroundLoader start, auto delete: false
19:49:17 T:10148 NOTICE: Previous line repeats 11 times.
19:49:17 T:10148 NOTICE: Thread FileCache start, auto delete: false
19:49:18 T:9868 NOTICE: Previous line repeats 7 times.
19:49:18 T:9868 NOTICE: Thread BackgroundLoader start, auto delete: false
19:49:22 T:1640 NOTICE: Previous line repeats 2 times.
19:49:22 T:1640 NOTICE: Thread JobWorker start, auto delete: true
19:49:28 T:6920 NOTICE: Thread FileCache start, auto delete: false
19:49:29 T:5172 NOTICE: Previous line repeats 11 times.
19:49:29 T:5172 NOTICE: Thread BackgroundLoader start, auto delete: false
19:49:50 T:8728 NOTICE: Previous line repeats 1 times.
19:49:50 T:8728 NOTICE: Thread LanguageInvoker start, auto delete: false
19:49:50 T:8728 NOTICE: -->Python Interpreter Initialized<--
19:49:53 T:8728 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <class 'urllib2.URLError'>
Error Contents: <urlopen error [Errno 11001] getaddrinfo failed>
File "C:\Users\Steven\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 1023, in <module>
index()
File "C:\Users\Steven\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 98, in index
if login():
File "C:\Users\Steven\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 649, in login
content = opener.open("https://signup.netflix.com/Login", "authURL="+urllib.quote_plus(authUrl)+"&email="+urllib.quote_plus(username)+"&password="+urllib.quote_plus(password)+"&RememberMe=on").read()
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 410, in open
response = meth(req, response)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 523, in http_response
'http', request, response, code, msg, hdrs)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 442, in error
result = self._call_chain(*args)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 382, in _call_chain
result = func(*args)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 629, in http_error_302
return self.parent.open(new, timeout=req.timeout)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 404, in open
response = self._open(req, data)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 422, in _open
'_open', req)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 1222, in https_open
return self.do_open(httplib.HTTPSConnection, req)
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib2.py", line 1184, in do_open
raise URLError(err)
URLError: <urlopen error [Errno 11001] getaddrinfo failed>
19:49:53 T:10576 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/
19:49:53 T:10576 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/) failed
19:49:53 T:5844 NOTICE: Thread BackgroundLoader start, auto delete: false
19:50:24 T:8260 NOTICE: Previous line repeats 2 times.
19:50:24 T:8260 NOTICE: Thread LanguageInvoker start, auto delete: false
19:50:24 T:8260 NOTICE: -->Python Interpreter Initialized<--
19:50:25 T:10576 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/
19:50:25 T:10576 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/) failed
19:50:25 T:2888 NOTICE: Thread BackgroundLoader start, auto delete: false
19:50:26 T:5012 NOTICE: Thread LanguageInvoker start, auto delete: false
19:50:26 T:5012 NOTICE: -->Python Interpreter Initialized<--
19:50:26 T:8260 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
index()
if login():
'_open', req)
raise URLError(err)
19:50:28 T:10576 ERROR: Previous line repeats 1 times.
19:50:28 T:10576 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/
19:50:28 T:10576 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/) failed
19:50:28 T:5260 NOTICE: Thread BackgroundLoader start, auto delete: false
19:52:40 T:7344 NOTICE: Thread JobWorker start, auto delete: true
19:53:16 T:7476 NOTICE: Thread BackgroundLoader start, auto delete: false
19:53:17 T:10656 NOTICE: Thread LanguageInvoker start, auto delete: false
19:53:17 T:10656 NOTICE: -->Python Interpreter Initialized<--
19:53:18 T:7248 NOTICE: Thread BackgroundLoader start, auto delete: false
19:53:18 T:10376 NOTICE: Thread JobWorker start, auto delete: true
19:53:23 T:5448 NOTICE: Thread LanguageInvoker start, auto delete: false
19:53:23 T:5448 NOTICE: -->Python Interpreter Initialized<--
19:53:39 T:6628 NOTICE: Thread LanguageInvoker start, auto delete: false
19:53:39 T:6628 NOTICE: -->Python Interpreter Initialized<--
19:53:39 T:5472 NOTICE: Thread BackgroundLoader start, auto delete: false
19:53:39 T:10576 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.program.chrome.launcher/?kiosk&mode=addSite&stopPlayback&url
19:53:39 T:10576 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.program.chrome.launcher/?kiosk&mode=addSite&stopPlayback&url) failed
19:53:39 T:10832 NOTICE: Thread LanguageInvoker start, auto delete: false
19:53:39 T:10832 NOTICE: -->Python Interpreter Initialized<--
19:53:39 T:1264 NOTICE: Thread BackgroundLoader start, auto delete: false
19:53:40 T:9884 NOTICE: Thread LanguageInvoker start, auto delete: false
19:53:40 T:9884 NOTICE: -->Python Interpreter Initialized<--
19:53:40 T:10576 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.program.chrome.launcher/?kiosk=yes&mode=showSite&stopPlayback=no&url=http%3a%2f%2fwww.netflix.com
19:53:40 T:10576 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.program.chrome.launcher/?kiosk=yes&mode=showSite&stopPlayback=no&url=http%3a%2f%2fwww.netflix.com) failed
19:53:40 T:1328 NOTICE: Thread LanguageInvoker start, auto delete: false
19:53:40 T:1328 NOTICE: -->Python Interpreter Initialized<--
19:53:40 T:9208 NOTICE: Thread BackgroundLoader start, auto delete: false
19:53:50 T:8824 NOTICE: Thread LanguageInvoker start, auto delete: false
19:53:50 T:8824 NOTICE: -->Python Interpreter Initialized<--
19:54:02 T:5132 NOTICE: Thread LanguageInvoker start, auto delete: false
19:54:02 T:5132 NOTICE: -->Python Interpreter Initialized<--
19:54:02 T:9348 NOTICE: Thread BackgroundLoader start, auto delete: false
19:54:02 T:10576 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.program.chrome.launcher/?kiosk&mode=addSite&stopPlayback&url
19:54:02 T:10576 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.program.chrome.launcher/?kiosk&mode=addSite&stopPlayback&url) failed
19:54:02 T:8012 NOTICE: Thread LanguageInvoker start, auto delete: false
19:54:02 T:8012 NOTICE: -->Python Interpreter Initialized<--
19:54:02 T:1212 NOTICE: Thread BackgroundLoader start, auto delete: false
19:54:04 T:3984 NOTICE: Thread LanguageInvoker start, auto delete: false
19:54:04 T:3984 NOTICE: -->Python Interpreter Initialized<--
19:54:04 T:10576 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.program.chrome.launcher/?kiosk=no&mode=showSite&stopPlayback=no&url=http%3a%2f%2fwww.netflix.com
19:54:04 T:10576 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.program.chrome.launcher/?kiosk=no&mode=showSite&stopPlayback=no&url=http%3a%2f%2fwww.netflix.com) failed
19:54:04 T:10344 NOTICE: Thread LanguageInvoker start, auto delete: false
19:54:04 T:10344 NOTICE: -->Python Interpreter Initialized<--
19:54:04 T:11120 NOTICE: Thread BackgroundLoader start, auto delete: false
19:54:18 T:10576 NOTICE: Previous line repeats 1 times.
19:54:18 T:10576 NOTICE: Log level changed to 2
19:54:18 T:10576 NOTICE: Enabled debug logging due to GUI setting. Level 2.
19:54:18 T:10576 DEBUG: ------ Window Init () ------
19:54:25 T:10576 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
19:54:25 T:10576 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
19:54:25 T:10576 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------
19:54:25 T:10576 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
19:54:25 T:10576 DEBUG: ------ Window Init (Settings.xml) ------
19:54:27 T:10576 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
19:54:27 T:10576 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
19:54:27 T:10576 DEBUG: ------ Window Deinit (Settings.xml) ------
19:54:27 T:10576 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
19:54:27 T:10576 DEBUG: ------ Window Init (Home.xml) ------
19:54:28 T:10576 DEBUG: CApplication::ProcessMouse: trying mouse action wheelup
19:54:30 T:10576 DEBUG: Previous line repeats 5 times.
19:54:30 T:10576 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
19:54:30 T:10576 DEBUG: Activating window ID: 10025
19:54:30 T:10576 DEBUG: ------ Window Deinit (Home.xml) ------
19:54:30 T:10576 DEBUG: ------ Window Init (MyVideoNav.xml) ------
19:54:30 T:10576 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/video/)
19:54:30 T:10576 DEBUG: ParentPath = [addons://sources/video/]
19:54:30 T:4012 NOTICE: Thread BackgroundLoader start, auto delete: false
19:54:30 T:4012 DEBUG: Thread BackgroundLoader 4012 terminating
19:54:31 T:10376 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/ImageLib.dll)
19:54:32 T:10576 DEBUG: CApplication::ProcessMouse: trying mouse action leftclick
19:54:32 T:10576 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.netflixbmc/)
19:54:32 T:10576 DEBUG: ParentPath = [addons://sources/video/]
19:54:32 T:10376 DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin NetfliXBMC('plugin://plugin.video.netflixbmc/','15','')
19:54:32 T:10376 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the NetfliXBMC (id=18) plugin...
19:54:32 T:6188 NOTICE: Thread LanguageInvoker start, auto delete: false
19:54:32 T:6188 INFO: initializing python engine.
19:54:32 T:6188 DEBUG: CPythonInvoker(18, C:\Users\Steven\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py): start processing
19:54:32 T:6188 NOTICE: -->Python Interpreter Initialized<--
19:54:32 T:6188 DEBUG: CPythonInvoker(18, C:\Users\Steven\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py): the source file to load is "C:\Users\Steven\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py"
19:54:32 T:6188 DEBUG: CPythonInvoker(18, C:\Users\Steven\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py): setting the Python path to C:\Users\Steven\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.pyamf\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.t0mm0.common\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.six\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.html5lib\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.socksipy\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.stem\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.simplejson\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.beautifulsoup4\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.myconnpy\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.addon.common\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.common.plugin.cache\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.free.cable.database\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.coveapi\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.requests\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.pytz\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.urlresolver\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.mechanize\lib;C:\Program Files (x86)\XBMC\addons\xbmc.debug\;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.parsedom\lib;C:\Users\Steven\AppData\Roaming\XBMC\addons\script.module.metahandler\lib;C:\Program Files (x86)\XBMC\system\python\DLLs;C:\Program Files (x86)\XBMC\system\python\Lib;C:\Program Files (x86)\XBMC\python27.zip;C:\Program Files (x86)\XBMC\system\python\lib\plat-win;C:\Program Files (x86)\XBMC\system\python\lib\lib-tk;C:\Program Files (x86)\XBMC;C:\Program Files (x86)\XBMC\system\python;C:\Program Files (x86)\XBMC\system\python\lib\site-packages
19:54:32 T:6188 DEBUG: CPythonInvoker(18, C:\Users\Steven\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py): entering source directory C:\Users\Steven\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc
19:54:32 T:6188 DEBUG: CPythonInvoker(18, C:\Users\Steven\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py): instantiating addon using automatically obtained id of "plugin.video.netflixbmc" dependent on version 2.1.0 of the xbmc.python api
19:54:33 T:10576 DEBUG: ------ Window Init (DialogBusy.xml) ------
19:54:36 T:6188 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
index()
if login():
'_open', req)
raise URLError(err)
19:54:36 T:6188 INFO: Python script stopped
19:54:36 T:6188 DEBUG: Thread LanguageInvoker 6188 terminating
19:54:36 T:10576 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
19:54:36 T:8452 INFO: CActiveAESink::OpenSink - initialize sink
19:54:36 T:8452 DEBUG: CActiveAESink::OpenSink - trying to open device DIRECTSOUND:{45AF5BAC-F397-4C35-96C8-8640235E4F05}
19:54:36 T:8452 DEBUG: CAESinkDirectSound::Initialize: Using Window handle: 919596
19:54:36 T:8452 DEBUG: CAESinkDirectSound::Initialize: secondary buffer created
19:54:36 T:8452 DEBUG: CAESinkDirectSound::Initialize: Initializing DirectSound with the following parameters:
19:54:36 T:8452 DEBUG: Audio Device : TX-NR828-4 (NVIDIA High Definition Audio)
19:54:36 T:8452 DEBUG: Sample Rate : 44100
19:54:36 T:8452 DEBUG: Sample Format : AE_FMT_FLOAT
19:54:36 T:8452 DEBUG: Bits Per Sample : 32
19:54:36 T:8452 DEBUG: Valid Bits/Samp : 32
19:54:36 T:8452 DEBUG: Channel Count : 2
19:54:36 T:8452 DEBUG: Block Align : 8
19:54:36 T:8452 DEBUG: Avg. Bytes Sec : 352800
19:54:36 T:8452 DEBUG: Samples/Block : 32
19:54:36 T:8452 DEBUG: Format cBSize : 22
19:54:36 T:8452 DEBUG: Channel Layout : FL,FR
19:54:36 T:8452 DEBUG: Channel Mask : 3
19:54:36 T:8452 DEBUG: Frames : 661
19:54:36 T:8452 DEBUG: Frame Samples : 1322
19:54:36 T:8452 DEBUG: Frame Size : 8
19:54:36 T:8452 DEBUG: CActiveAESink::OpenSink - DIRECTSOUND Initialized:
19:54:36 T:8452 DEBUG: Output Device : HDMI - TX-NR828-4 (NVIDIA High Definition Audio)
19:54:36 T:8452 DEBUG: Channel Layout: FL,FR
19:54:36 T:10376 DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - plugin exited prematurely - terminating
19:54:36 T:10576 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/
19:54:36 T:10576 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/) failed
19:54:36 T:10576 DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/video/)
19:54:36 T:10576 DEBUG: ParentPath = [addons://sources/]
19:54:36 T:6416 NOTICE: Thread BackgroundLoader start, auto delete: false
19:54:36 T:8452 DEBUG: CAESinkDirectSound::CheckPlayStatus: Resuming Playback
19:54:36 T:6416 DEBUG: Thread BackgroundLoader 6416 terminating
19:54:36 T:10576 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
19:54:37 T:7292 DEBUG: CMMNotificationClient::OnPropertyValueChanged: Changed device property of {0.0.0.00000000}.{45af5bac-f397-4c35-96c8-8640235e4f05} is {9855c4cd-df8c-449c-a181-8191b68bd06c}#0
19:54:37 T:10576 DEBUG: ------ Window Deinit (Pointer.xml) ------
19:54:38 T:10576 DEBUG: ------ Window Init (Pointer.xml) ------
19:54:41 T:10576 DEBUG: Keyboard: scancode: 0x5b, sym: 0x0137, unicode: 0x0000, modifier: 0x10
19:54:41 T:10576 DEBUG: CApplication::OnKey: win-leftwindows (0x10f0d6) pressed, action is
19:54:41 T:10576 DEBUG: ------ Window Deinit (Pointer.xml) ------
19:54:41 T:10576 DEBUG: CWinEventsWin32::WndProcWindow is active
19:54:41 T:10576 DEBUG: CWinEventsWin32::WndProc: Focus switched to process C:\Windows\explorer.exe
19:54:41 T:10576 DEBUG: ------ Window Deinit (DialogKaiToast.xml) ------
19:54:46 T:10576 DEBUG: ------ Window Init (Pointer.xml) ------
19:54:51 T:10576 DEBUG: ------ Window Deinit (Pointer.xml) ------
19:55:08 T:7344 DEBUG: Thread JobWorker 7344 terminating (autodelete)
19:55:08 T:10376 DEBUG: Thread JobWorker 10376 terminating (autodelete)
19:55:08 T:10576 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib.dll)
