2014-12-09, 11:16
Since it's chrome which plays the videos its a chrome and Netflix HTML 5 question
Quote:21:27:07 T:12844 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeDecodeError'>
Error Contents: 'ascii' codec can't decode byte 0xc3 in position 930: ordinal not in range(128)
File "N:\_xbmc_stuff\XBMC_template\portable_data\addons\plugin.video.netflixbmc-master\default.py", line 1067, in <module>
listSeasons(name, url, thumb)
File "N:\_xbmc_stuff\XBMC_template\portable_data\addons\plugin.video.netflixbmc-master\default.py", line 407, in listSeasons
content = getSeriesInfo(seriesID)
File "N:\_xbmc_stuff\XBMC_template\portable_data\addons\plugin.video.netflixbmc-master\default.py", line 509, in getSeriesInfo
content = load(url).encode("utf-8")
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 930: ordinal not in range(128)
21:27:07 T:5536 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.netflixbmc/?mode=listSeasons&name=Chuck&thumb=https%3a%2f%2fscdn.nflximg.net%2fimages%2f2220%2f9362220.jpg&url=70157475
21:27:07 T:5536 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.netflixbmc/?mode=listSeasons&name=Chuck&thumb=https%3a%2f%2fscdn.nflximg.net%2fimages%2f2220%2f9362220.jpg&url=70157475) failed
(2014-12-10, 03:23)thedude459 Wrote: This is what I am getting when I try to watch a tv show:
<snip>
WindowsError: [Error 2] The system cannot find the file specified
<snip>
(2014-12-10, 22:24)derelict Wrote: i get this while starting any episode:
<snip>
<snip>
This is the latest Netflixbmc 1.3.7 as of yesterday
(2014-12-11, 01:30)corona Wrote:(2014-12-10, 03:23)thedude459 Wrote: This is what I am getting when I try to watch a tv show:
<snip>
<snip>
Do you have netflixbmc set to use Internet Explorer or Chrome?
Assuming it's on chrome (default), this to me looks like it can't find the chrome launcher plugin or, more likely, that it can't find chrome.
Do you have the chrome launcher addon installed? Check in enabled addons for it and check it's configuration to be sure it's activated and verify the path to chrome is correct. Try running the chrome launcher addon separately and see if it's built in youtube launcher works.
If you're trying to use internet explorer, I suggest trying to change to chrome, even if you have to install chrome first. I haven't tested the plugin on windows at all yet personally so can't necessarily help a lot more.
<snip>
<snip>
This is almost guaranteed to be the utf-8 issue that crept in after me 'fixing' a bad merge I made which wasn't actually bad. I've brought in what should be a real fix and upreved the repo, try updating the plugin again now.
(2014-12-11, 03:59)JasonPell Wrote: If you can post the log file which has the script error
12:47:54 T:3808 NOTICE: URL: https://www.netflix.com/Login
12:47:54 T:1000 NOTICE: URL: https://www.netflix.com/Login
12:47:55 T:1000 ERROR: C:\Users\horstepipe\AppData\Roaming\XBMC\addons\script.module.requests\lib\requests\packages\urllib3\connectionpool.py:730: InsecureRequestWarning: Unverified HTTPS request is being made. Adding certificate verification is strongly advised. See: https://urllib3.readthedocs.org/en/latest/security.html (This warning will only appear once by default.)
InsecureRequestWarning)
12:47:58 T:3724 ERROR: Previous line repeats 1 times.
12:47:58 T:3724 NOTICE: Thread LanguageInvoker start, auto delete: false
12:47:58 T:3724 NOTICE: -->Python Interpreter Initialized<--
12:47:58 T:3724 NOTICE: URL: http://api-global.netflix.com/desktop/odp/episodes?languages=de-US&forceEpisodes=true&routing=redirect&video=70242311&country=US
12:47:59 T:2332 NOTICE: Thread FileCache start, auto delete: false
12:47:59 T:3724 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Contents: 'ascii' codec can't decode byte 0xc3 in position 10: ordinal not in range(128)
File "C:\Users\horstepipe\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 1085, in <module>
addSeriesToLibrary(seriesID, name, url)
File "C:\Users\horstepipe\AppData\Roaming\XBMC\addons\plugin.video.netflixbmc\default.py", line 796, in addSeriesToLibrary
filename = (''.join(c for c in filename.encode("utf-8") if c not in '/\\:?"*|<>')).strip(' .')
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc3 in position 10: ordinal not in range(128)
12:48:04 T:1960 NOTICE: Thread FileCache start, auto delete: false
(2014-12-11, 06:31)corona Wrote: How does everyone else feel about this plan?
Quote:The repo still lists 1.3.7 as latest version.
http://www.alelec.net/kodi/repo/addons.xml
