Issue with Library Mode showing multiples
Question
Hi all,
First off here is my info for my XBMC player:
- Raspberry Pi using XBian (latest)
- Frodo
- Connecting to my Synology 212J NAS via NFS
Here is the problem: in Library Mode, every song in an album appears 2 or 3 times (3 seems to be the norm), but if I turn it off it's ok each song shows only once.
I did another test and on my Win8.1 w/Frodo box and it shows up to 8 times, it connects via UPnP.
Has anyone seen this & how do I fix this?
Many thanks!
there were issues like this with older frodo's but they should have been fixed a long time ago. i know nothing about xbian, which seems to be based somewhat on frodo. can you try with latest gotham nightlies with a clean db and tell me if the issues persist.
Thanks - was hoping for a simpler fix Smile
Here is why I don't think your solution is the right path: I get the same issue on Windows, and got the same with RaspBMC.
BTW if not in library mode no problem.
Problem solved - deleted DB and re-scanned from scratch and problem wooshed away Smile
Issue with Library Mode showing multiples0
