  • 2
  • 4(current)
  • 6
  • 9
AMLogic hardware video decoding in nightly builds
#46
(2014-01-11, 08:45)VictorDUA Wrote: No. If amlogic enable I don't have picture at all only sound. Player do not switch to full screen and when I try to play movie it's played background and only sound. If I manually switch full screen I have black screen and sound. When I turn amlogic off - everything fine except HW.
i have the exact same issue with my amlogic box as welll its a bluetimes mx5 Sad all apks dont work
(2014-01-13, 17:02)manül Wrote: Does anyone know why there are no PVRs included anymore in nightly builds for android/arm since 28.12?
was a bug - should be fixed ...
AppleTV4/iPhone/iPod/iPad: HowTo find debug logs and everything else which the devs like so much: click here
HowTo setup NFS for Kodi: NFS (wiki)
HowTo configure avahi (zeroconf): Avahi_Zeroconf (wiki)
READ THE IOS FAQ!: iOS FAQ (wiki)
(2014-01-13, 16:59)davilla Wrote: logcat please before you nuke the box.
Where I can read how to do this ? ThanX.
id love to know as well
my raspberry pi psu just died and this bluetimes mx5 box has been collecting dust for the past half year
the company who makes them are pretty useless with firmware upgrades etc very slack
Big Grin
I can set ADB on my PC (Win8.1) but how I can connect it to my Amlogic 8726-MX without USB and WIFI ? I'm on wire network.
http://stackoverflow.com/questions/26047...b-over-tcp
so nightly jan 14th most recent and then a fresh copy of my boxes new firmware and im in business... id like to thank the devs xbmc who made my box very happy after sitting away for so long being a useless paper weight Smile
(2014-01-14, 10:48)VictorDUA Wrote: I can set ADB on my PC (Win8.1) but how I can connect it to my Amlogic 8726-MX without USB and WIFI ? I'm on wire network.
adb connect IP.of.your.box
can confirm on AMLogic 8726 M6
Audio is slightly Offset by 0.225 sec issue aswell
Don't know how to post log in right way, so
LOG: https://mega.co.nz/#!XQBQUDwQ!LxVhWgh25e...jRXGnB2tXQ
Android: DroidTV MX 2013-07-25 firmware with XBMC http://forum.androidgadget.co.uk/showthread.php?tid=300 but tested many more with same result.
XBMC: http://mirrors.xbmc.org/nightlies/androi...bi-v7a.apk
Open XBMC-Play file-Close XBMC
Only sound - no video - no fullscreen with AmLogic enable.
Thanx.
thanks.
This also (somehow) fixed my previously reported issue. My self compiled PVR now loads fine.
(2014-01-08, 15:47)manül Wrote: Anyone know why PVR loading fails with "bad status (6)" since enabling this feature? Debug log doesn't give me more hints and library dependencies haven't changed. PVR loads fine on nightly builds before 28.12.
thanks.
tested with latests nightly build from today,
can confirm pvr add-on VU+ is 1.9.9 version and working.
Greetings, DjKolk
Edit by memphiz: fixed the quote...
Me too Sad
Me too Sad
Me three :/. I did notice that the xbmc-20140112-5ce3697-master-armeabi-v7a.apk does play .mp4, .avi & .mkv files, but playing a .rmvb file causes the same "black screen & audio only" effect. I have only tried enabling/disabling the MediaCodec & libstagefright (in the Settings -> Video menu) without any change.
K.
Me too Sad
i ended up getting it working upgrade your box to the latest august firmware from bluetimes then install nightly and it should work it worked for me but with a sound delay of about 0.25 seconds and larger mkv's are still struggle city for the box it comes to its knees skipping millions of frames
  • 2
  • 4(current)
  • 6
  • 9
AMLogic hardware video decoding in nightly builds1
