Vaikin
Posting Freak
I dont think discart is included anywhere...other than music views.
2014-05-07, 02:58
(This post was last modified: 2014-05-07, 04:58 by inv3ntor.)
Just updated to v13 gotham and nox v5. Alot of changes it seems.
In movies showcase view, it no longer shows the year of the movie or the imdb rating/votes. Also during playback when you press "i" it no longer shows these 2 things. This is kinda dissapointing.
Also banner view for tv shows was good before with the fanart visible above the low lying banners, now its like other skins just a wall of banners, also dissapointing.
Seems home window less customizable as well, used to have icons with the labels, now we cant. And adding things to submenus seems to only give a list of 16 useless choices.
Also what happened to the bluray/dvd cases on movies? Now we just get standard posters with a very subtle "sd" or "hd" once we are viewing them.
Also i used to display the movie count for 2 smart playlists on the home window, this is also no longer available, my only option is to display the entire mvoie library stats for them.
Even the TV "episode" view is gone as well. Also viewing tv shows in banners & seasons as "shift"i no longer have "watched" flags or an episode count at the bottom of shift. Seems instead i have a star for things that are not watched, or is that for things that are new?
Also cinema experience is no longerin context menu or the movie info screen, and creating a home menu item for it does not work like it used to either.
I know V13 has only just launched, but tbh im thinking of rolling back to v12 and nox 4.
Are these things that will be fixed in updates coming soon? It seems alot has been removed, and little added.. Seems v4 to v5 was just removing alot of cool features, and not really giving us anything new.
Is that logo view? My library has plain text logos. Where did you scrape those from?
I noticed what may be a small bug today - if you have your movies display as sets when you go to the ".." option to return back from the submenu of the set the background art displays a random movie picture, it doesn't maintain the theme of the set (i.e. if browsing the Fast & Furious collection it may display an image from Black Swan when I highlight this option) - this may have happened in previous releases also but I just noticed it in this one.
removed151214
Unregistered
removed151214
Unregistered
Posts: N/A
(2014-05-07, 07:23)Zokkel Wrote: (2014-05-07, 02:58)inv3ntor Wrote: Seems home window less customizable as well, used to have icons with the labels, now we cant. And adding things to submenus seems to only give a list of 16 useless choices.
You can add almost anything to the submenu. It requires just the knowledge of the XBMC build-in functions (http://wiki.xbmc.org/index.php?title=Lis..._functions). A bit more work, but I'm getting there and I'm a noob at this stuff.
You can also use the up and down arrows above those 16 useless choices to show video library links, music library, favourites, add-ons or playlists to choose from instead
The popup dialog that was added in Live TV when switching channels is a bit redundant now that there is a whole load of info shown at the bottom, can the popup be removed?
I think there is a small bug with setting a viewtype.
Let's say I have several tv shows, some with only one season and a more with several seasons.
I have set Low List (extra low) for Tv shows, Low List (extra low) for seasons, and List for episodes.
But, for the seasons viewtype it does not remember this or set this for every tv show. Some of them are Low list and random shows go back to List. Then i would have to put it back to Low List.
Hope I made it clear.
