Koloss
Senior Member
2013-11-18, 23:21
(This post was last modified: 2013-11-19, 00:24 by Koloss.)
Thanks, @Milhouse:, I test this Build now and give you a feedback tomorrow!
Aeon mq 5, ace skin didnot running same problem! Incompatible
Temperatur test follow.
pikoli
Junior Member
hey guys!
is it still possible to change gui resolution with <guires> tags in advacedsettings.xml? I tried it on some latest gotham builds, but it doesn't seem to be working. I have 256Mb pi, so this feature would be useful.
for some reason when I do a fresh install using wired connection, can't get past the welcome screen for networking... just sits there saying working... with the spinning symbol.
I know it's connected because I can ssh in, but can't figure out how to close/get past the first-use prompts
Ubuntu 13.10 | 10TB | myth .27 - HVR2250 - HVR1250 | XBMC Gotham | Radeon 4550
Linux Mint 15 | XBMC Gotham | IntelHD4000
Openelec Custom | XBMC Gotham | Raspberry PI
Cyanogen 11 | XBMC Gotham | Samsung GSIII
2013-11-19, 04:29
(This post was last modified: 2013-11-19, 04:45 by dubsides.)
thank you so much I tried searching the thread with relevant terms but didn't come across it, thanks again!
/oh my god the cmyth pvr is so much better than it used to be!
I tried to turn on myth logging (in the myth config menu) and it kept crashing. Gave up. I will try again with the next build.
Are there any Frodo builds that support mythbackend 0.27? I upgraded the mythbackend before realizing that the Frodo mythpvr doesn't support 0.27...
Have the last rbej Gotham build working, but has some issues with addons, is a bit unstable--definitely not wifeproof. Trying to show her that it's as easy to use as the cable box. Failing.
