2013-11-25, 00:16
I'm having strange LIRC problems with MilhouseVHs last two builds.
With the preovious build on a cold boot the remote would work normally apart from double pressing everywhere. After a reboot it would work normally apart from the 'Select / OK' button did not work. Reboot again and it all would work fine .... until next reboot when it would go back to double presses....etc. This was repeatable and I lived woth it for a good few days.
On the newer build, I just get the issue with the 'Select / OK' key not working, no matter how many times I reboot.
I've checked the logs after enabling debugging and there is no mention of the 'select / ok' key presses at all, but other keys get logged as expected. OpeneELEC doesn't make troubleshooting LIRC isssues very easy and I'm a bit stumped now.
Any ideas?
Any ideas?
