Same problem here with Windows and beta 1, the strange is that I was constantly updating to latest nightly without a glitch as matter subtitles but since Gotham appeared in nightlies all have problem on me
There's no substitute for experience
amet
Retired Team-Kodi Member
its all useless without log, your log shows nothing... zero... bluechris didnt upload anything so I cant help, sorry .. my crystal ball is broken
I have the same problem. I'm not home right now so I can't post my log file. But the subtitle doesn't show.
zambo
Junior Member
2014-03-07, 11:49
(This post was last modified: 2014-03-07, 12:02 by zambo.)
i have the same problem no subtitle showing up.
maybe somebody should make a tutorial video on this subtitle issue how to make it work for gotham 13.
with step by step.and then show a movie with the subtitle working.
( ps anybody would like this that have problem with subtitle)...vote for the mods to help us here
Maybe it needs a clean install? I will try it
Dont work only with video addons.
I have experienced the same problem. Subtitles do not show up. I have looked in the log file for errors but I can't seem to find any. I can search and download subtitles and confirm that the subtitle file really is downloaded and placed in .../userdata/addon_data/service.subtitles.opensubtitles/temp/. So I think the problem is not with the opensubtitles service rather with the player not finding the subtitle file. Maybe there is something with the setting of where subtiles should be placed?
My memory may be faulty, but as I recall, it seems to work when playing a file on hard disk. But it definitely does not work with a streaming addon.
When I find more time I will try to investigate more and also provide a log-file.
Apple TV2 running XBMC Gotham beta
I see also that logs have no info for the problem... i did also and i havent spot anything and its same like the people that allready posted logs...
SMB or Local video files get subtitles from opensubtitles fine... video plugins (in specific i use plexbmc to connect to a server of myne) they dont.
I rolled back to XBMCSetup-20140303-8a408a4-master.exe 03-Mar-2014 07:47 version and i am fine atm... its the last version before the beta1
I just install above with no problem but to be sure I 1st backup
Ewout
Junior Member
I also rolled back to the March 3 version. Subtitles work fine in this version. So there is definitely a bug in Gotham beta 1. Hope this will be solved soon.
