Openelec RPi v3.95.1 bug thread?
Forgive me for my ignorance, is there a specific thread for the bug in Openelec V3.95.1?
Where should I report them?
Config, audio player only:
2T HDD <USB> RPi2/Kodi <HDMI> Denon AVR-2313 <HDMI> LG TV 55UF860V
There isn't a dedicated one for the Pi, so here would be fine.
I've come across one bug so far and it only happens on one of my TV's ( a Panasonic)
When it urn the TV off and back on again, HDMI-CEC doesn't work.. I have to reboot the Pi to get it to kick back in.
I'll grab the logs when i get home tonight to see what's happening but has anyone else come across this?
I have the exact opposite with a Panasonic TV too.
If I reboot pi I have to reboot TV too after for some keys to work again.
But I think it was happening in frodo too. (openelec 3.2.4).
Moved from thread http://forum.xbmc.org/showthread.php?tid...pid1648572
I have just installed the latest version of OpenElec with Gotham beta 1 and am having massive problems with movies pausing / stuttering. While this use to happen occasionally with XBMC 12.2 it was nowhere near as bad as with Gotham. I have DTS passthrough enabled, which from reading many posts on the subject seems to be the issue. Is there a fix for this yet? I have posted snippets of the log below from when the pause occur..
18:39:49 T:2706371664 DEBUG: Pause -0.45,-0.48 (A:10 V:10) EOF:0 FULL:0 T:0.40
18:39:49 T:2706371664 DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
18:39:51 T:2706371664 DEBUG: Resume 0.59,0.46 (A:01 V:01) EOF:0 FULL:0 T:0.40
18:39:51 T:2706371664 DEBUG: OMXClock::OMXSetSpeed(1.00) pause_resume:1
18:39:52 T:2706371664 DEBUG: Pause -0.61,-0.61 (A:10 V:10) EOF:0 FULL:0 T:0.80
18:39:52 T:2706371664 DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
18:39:53 T:2863658064 DEBUG: script.grab.fanart: Movie - Crank
18:39:53 T:2863658064 DEBUG: script.grab.fanart: Video - Crank
18:39:53 T:2863658064 DEBUG: script.grab.fanart: Global - Crank
18:39:55 T:2706371664 DEBUG: Resume 0.88,0.81 (A:01 V:01) EOF:0 FULL:0 T:0.80
18:39:55 T:2706371664 DEBUG: OMXClock::OMXSetSpeed(1.00) pause_resume:1
18:39:56 T:2706371664 DEBUG: Pause 0.03,0.04 (A:10 V:10) EOF:0 FULL:0 T:1.60
18:39:56 T:2706371664 DEBUG: OMXClock::OMXSetSpeed(0.00) pause_resume:1
(2014-03-10, 10:42)danmedhurst Wrote: I've come across one bug so far and it only happens on one of my TV's ( a Panasonic)
Can you report CEC issues here:
https://github.com/Pulse-Eight/libcec/issues
make sure you include a log with debug enabled.
(2014-03-10, 13:20)robe1 Wrote: Moved from thread http://forum.xbmc.org/showthread.php?tid...pid1648572
Can you try the Milhouse build from the other thread. That does have a patch not in beta that can improve buffering behaviour.
(2014-03-10, 12:00)host505 Wrote: I have the exact opposite with a Panasonic TV too.
I've solved this for LG
Use a timer to turn off XBMC and have no more problems with CEC (simple link LG).
I use power from USB of LG,for reboot just disable usb power on TV then enable afther you shootdown PI with timer.
This works well on LG on Panasonic I dont know You must tray ¿¿¿
XBoxMediaCenter (Kodi Leia) 18.0 , LibreElec RasPi3 Libreelec-Leia Skin AeonMQ6
Will do ... do you think this is a buffering issue? Have tried setting the buffermode parameter in advancedsettings.xml file to 1 so all streams are cached but it did not help. Not sure if this is the same thing or not.
(2014-03-10, 13:20)robe1 Wrote: 18:39:53 T:2863658064 DEBUG: script.grab.fanart: Movie - Crank
Also, the fanart grabber script is doing stuff while you are getting buffering. Can you try disabling/uninstalling?
@popcornmix
Sorry to go back with these bugs you already know but you don't know how to fix.
See thread OpenELEC Testbuilds for RaspberryPi Part 2
#3163 with log
#3166
#3168
#3198
Clean install in another formatted SD card: v3.95.1
Personal set-up:
Network Wi-Fi
Service SSH
Apparence > International > UK (24), Timezone
Music > Playback > Visualisation: None
System > Video output: 1680 x 1050
System > Audio output > Number of channels: 5.0
Input device > Peripherals > CEC Device to power on: AVR, Device to power off: AVR, When the TV is switched off: Ignore
When I boot, no system sound
I tried the 3 players to play flac 2CH file: no sound
Came to change screen resolution, as soon I click on YES I got the system sound.
Moreover this time I had a bug you though to be fixed:
Very fast flickers between YES and NO. I had to click my remote different buttons to stop after a while. The same started again between 3 screen keys (Menu SYSTEM, system, shut down) and I had the click long time to stop it.
Let me know what you want for more info
Thanks for you devotion.
D'oh, wrong thread...
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
(2014-03-11, 03:00)MilhouseVH Wrote: D'oh, wrong thread...
Is it for my report #11?
Not the wrong thread because I have exactly the same issues with v3.95.1
I say exactly.
Just let me know what kind of test and log you want.
No, it was me posting in the wrong thread.
Hi popcornmix
As suggested I tried the latest Milhouse build to stop the film pauses with DTS passthrough enabled and it did not work, still had long pauses every 30 seconds or so. I also disabled the fanart add-on and increased the gpu memory from 128 to 256 but with no success.
I have uploaded a copy of the logs here - http://pastebin.com/aG4jEJq8
A couple of things I have noticed, not sure if they will help:-
I have recently upgraded my amplifier. On my old amp is only supported 1080i and I didn't have the pauses. My mew amp supports 1080p and the pauses are very bad. Is there a way of forcing XBMC to 1080i so I can test this out on the new amp?
I also tried experimenting with different frame rates - set at 24, 30 and 50 the pauses happened but it seemed to get further into the film before they started. Withe the frame rate at 60 they started almost immediately.
Openelec RPi v3.95.1 bug thread?0
