Oh, thanks! Good to see it's being worked on.
fritsch
Team-Kodi Developer
It's being worked on since many months without any real solution as of today.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
That's too bad. Does this mean all users of this hardware are affected, regardless of distribution and config? I thought (after years of Nvidia and AMD/ATI frustration) buying an Intel-based box was the safer bet.
fritsch
Team-Kodi Developer
Only Celeron, Pentium HSW Gen1 Users.
There are workarounds:
a) Disable "Prefer VAAPI Render Method" under Video -> Acceleration
b) Set Deinterlace to Auto and Deinterlacing-Method to De-Interlace or Bob (basicaly _not_ VAAPI-BOB, MCDI, MADI).
Thanks! But I can't find that option, I only have "Prefer VDPAU video mixer" and "Allow hardware acceleration (VAAPI)". Which do I disable?
I always have the settings on expert, but there's no option called Prefer VAAPI Render Method, only "Prefer VDPAU video mixer" and "Allow hardware acceleration (VAAPI)". Apart from an extra VDPAU setting, my screen looks more or less like your screenshot (which, fwiw, doesn't have an option called that either).
Is it different on Helix? I'm on Gotham.
fritsch
Team-Kodi Developer
On Gotham, this setting does not exist. And nothing will help you to workaround this. As we don't have code in there that can do the same.
I see. Then I'll just update to Helix. Looks like it's safe to just change the ppa to unstable?
2014-11-24, 08:55
(This post was last modified: 2014-11-24, 09:54 by wsnipex.)
Using XBMCBuntu / Gotham 13.2
I have a problem updating the Music library, when i get the system to scan and add to the library, it will do a few artists then go into a crash/reboot cycle, with a black screen and an shaped cursor on a black screen. i can attach an error log but can't find that facility
At the risk of wrath, I'll just just paste it
mod edit: my WRATH be upon you, log spam removed
fritsch
Team-Kodi Developer
2014-11-24, 08:56
(This post was last modified: 2014-11-24, 08:57 by fritsch.)
Thanks for posting all those logs inline, so that nobody can actually read them
Reproduce with 14.0 beta4 - I think I have fixed that issue with id3 tags long ago.
Edit: Btw. your installation is outdated, run: sudo apt-get update followed by sudo apt-get dist-upgrade and install proper updates
Upgraded to Helix, and removed the Prefer VAAPI check. I've only tested with one video file so far, but no freezes. Thanks, @fritsch!
One question out of curiosity, though... Are there any problems with this workaround? Any benefits (performance or otherwise) in preferring VAAPI?
fritsch
Team-Kodi Developer
It will cost CPU load, cause the surfaces are copied to the system memory.
I see. Thanks! Do you think the extra load could cause problems for an Asus Chromebox playing regular 1080p h264 videos (I rarely do bluray ISOs or similar and never 3D), or is it more of a power consumption issue? (Sorry for the stupid questions.)
Is there a plan to update XBMCBuntu for Kodi?
