2006-03-30, 01:56
i had a share on my windows xp machine that had all of my tv shows shared through a smb share and it worked great. i now am testing out the windows vista v5342 32bit version on the same machine but i am not able to connect with xbmc through the same setup.
if anyone has any idea on how i would be able to stream my tv shows onto my xbox through xbmc with windows vista any and all help would be appreciated!
since vista is still in heavy beta development i would recommned going to vista boards and also asking about smb shares there.
smb is a popular choice, if it is not supported/working under the current vista build, im sure the vista community will be/have made a work around.
just a thought.
i have same problem with windows vista build 5384
plz help
Washy
Junior Member
same here - i can access the internet, but when i try to logon to a shared folder... i get a username/password popup. if it were a bad setting, i think i would get a "can't connect to network error message" or something similar.
all the settings and permissions are the same as my xp os settings.
anyone find a solution yet?
washy
elupus
Team-XBMC Developer
since they have tightened security in vista.. there are alot that can go wrong..
file permissions may be off.
share permissions.
guest account might be disabled
Washy
Junior Member
correct me if i' wrong, but enabling the guest account with the right permission's to a share just lets you login without a user/pass. which doesn't work in vista either.
so guest enabled - smb://computername/share
guest disabled - smb://username:password@ip/share/
has anyone found a solution or work around for this yet?
the guys that were having this problem did you end up going back to xp?
thanks
Washy
Junior Member
i gave up with smb, but the program ccxgui_1.41 worked without any problems.
