2014-04-11, 22:19
(This post was last modified: 2014-04-11, 22:23 by skrowl.)
Has anyone found a good Android app for controlling the Fire TV? The era of the hard plastic controller is over, in my opinion. Remotes are just one more thing to lose / need batteries / need recharging / etc. Yatse + BlueBoard makes my Ouya 100% smartphone controller, and I'm hoping there's something similar that I can do on my Fire TV. There are lots of "ZOMG make your phone a remote for your PC!" apps on Google Play Store, but all of them seem to require a proprietary server software to be running on your Windows PC / Mac.
TL;DR - Need an app on my phone that acts as a bluetooth keyboard and/or controller for Fire TV.
2014-04-11, 22:23
(This post was last modified: 2014-04-11, 22:24 by denmalley.)
This might be like predicting the stock market but what's the general feel for whether the ATV2 will hold its inflated value over the next few months, now that the fire TV is out? I'm thinking it might be nice to get two fire TV's for the price of one ebay'ed ATV2, but kind of want to make sure my first one works well enough and passes the Spouse Test before giving up the apple and getting the fire.
This is my first post here.
Did anyone try Airplay?
Airplay and Yatse don't work for me.
2014-04-11, 23:03
(This post was last modified: 2014-04-11, 23:03 by ozkhan1.)
Is FTV HDMI CEC compatible?
If the answer is yes, you might not need a different remote and you can just your TV's remote.
2014-04-11, 23:19
(This post was last modified: 2014-04-11, 23:23 by thess.)
Remote tangent, the fix for the Ortek MCE IR problem I mentioned earlier (up/down keys getting double pressed) was to set the device 'command repeat' in the Harmony software for the device to 1. (Not 3, not 0, 1.) NOW I have my Harmony remote fully controlling the Fire and XBMC the way I want it to. (*Thinks about making snarky "boyfriend acceptance factor" joke, refrains*)
On another tangent: In the last 10 minutes, the Voice Search button on my Fire remote has stopped working. It appears to work, registers your voice volume, says "Thinking..." and never returns any results. Does anyone know if the Voice Search has to talk to Amazon servers to work? If anyone is reading this with the Fire in front of them, can you give your Voice Search a quick test and tell me if it's working? Wondering if something is down on Amazon's end. (Have restarted the Fire...it was literally working like 10 minutes ago.)
EDIT: It's working again now, out of nowhere. So I do think there's a cloud-side component to the Voice Search, maybe?
